» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 12-06-2007, 01:15 PM   #31 (permalink)
RBYCC
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL
Originally Posted by mcbear View Post
Talk to Jonathan at Blueridge.
There are several ways to get more reliable power out of the 103/104 motors but no matter which way you go, look toward $7000 for the entire package.
The Twin Turbo kit cost plus installation plus tuning seems to run up to $7K by the time it is all done.
A motor swap to nearly anything is at least $7K once you buy the motor/tranny, driveshaft issues, electronics, mounting issues, tuning up etc. It usually tries to start plug and play but 40-70 hours of swap time just adds up.
At some point you might look at just buying a 400E or 500E, selling your E320 and having a fully engineered solution that gives you 275-320HP out of the box. For the bump to 400E I know it would be a cheaper option and depending on the quality of 500E, it might be just above break even.
McBear
You're being conservative...!!
Brian Murphy @ Willow Automotive ran about 110 manhours, with about 20 - 30 spent trying to resolve issues with the TT kit.
Not many of the "inexpensive" twin turbo kits available...
Totally agree with you about looking for a 500E.
If I didn't have my original 62K mile 1988 Coupe, I wouldn't have put the money into the twin turbo install.
There was a very nice 500E in Cali that just sold on another forum for $18250.00
You couldn't include the cost of a clean well maintained low mileage W124/C124 with a sound stock M103/M104 motor and add a twin turbo with required suspension mods, exhaust, wheels, tires, etc for that price !!!!!
Ed A.
P.S.
The turbos sure love these 40 degree and lower temps...feels like it added about 50HP !!!
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 12-10-2007, 06:32 PM   #32 (permalink)
coastline
Date registered: Aug 2007
Vehicle: Mercedes
Final Finished my Full custom turbo install,still need to pull the valve cover and repaint as well as the intake tubes and do some cleaning..Have my eye on an aluminum radiator from griffin and a few different intercooler piping issues...
End result
267RWHP
251Torque
7 lbs this is reliable I made well over 320Rwhp on 13lbs but it was either head gasket or burned pistons and proved unreliable but very fun...
E220 Euro spec Cabriolet 155hp-stock If I remember it was 120 or so stock at the wheels...
T3 Turbo on Custom Manifold
3 inch stainless steel mandrel bent exhaust
two 3 inch magna flow stainless mufflers
single 3 inch magnaflow stainless steel converters
Front mount intercooler
Tial 38mm wastegate with 7 psi spring
Xs blow off valve-unused currently
Aero adjustable fuel pressure regulator
Greddy injector holders x2 welded and smoothed on stock intake manifold
six 44 lbs Rc engineering injectors
split second additional injector controller controlling 2 additional injectors
K & N air filter
Recalibrated intake air temp sensor
External transmission & oil cooler
HKS turbo timer
Stainless mandrel bent intake piping
Stock crank,rods,pistons,head gaskets
3900+lbs bullet
sorry about the horrible pics will ha
E4/// Turbo-unleashed
coastline is offline   Reply With Quote
Old 12-10-2007, 09:47 PM   #33 (permalink)
mcbear
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Originally Posted by RBYCC View Post
McBear
As I think more about it, you are right. the 40-70 number is what I have had to write checks for to the guys but that doesn't include my time or other folks that come by that have skills and end up either fabricating or measuring or just adding those extra few gray cells at the right time.
I know we dropped a 350 crate into a Datsun 280Z in 65 total man hours from removal of the original motor to turning the new one on but that was a well planned job and had been done before by all members of the four man team. Once you get into relooming harnesses, it starts getting messy and costly.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2000 S500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 12-11-2007, 06:41 AM   #34 (permalink)
RBYCC
RBYCC's Avatar
End result
267RWHP
251Torque
3900+lbs bullet
AH-MAZING !!!!!
You did it right.....
Built max power with max reliability and real world you'll go as fast if not faster then those that are claiming to build 600-1000HP hand grenades capable of 200MPH.
"POWER THAT DOESN'T GO TO THE GROUND IN A CONTROLLED MANNER IS NO POWER AT ALL "
Post some performance numbers....probably low 5 seconds to sixty or a bit better ?
ED A.
Old 12-11-2007, 09:27 AM   #35 (permalink)
coastline
Vehicle: Mercedes
At 9lbs i was just under 300RWHP but lean at 6000rpm-no matter what,I am convinced that someone that knows the split second unit better than I do can get me safely running at 9psi...Factory Fuel pump in my case could not deliver enough fuel at 5000rpm on up....had to swap to bigger pump
Old 12-11-2007, 09:36 AM   #36 (permalink)
coastline
Vehicle: Mercedes
Originally Posted by chrisdpham View Post
Speaking of performance for the M119 engine.
Does anyone know the specifics as to supercharging that motor? I've seen numerous post or people who have tried with various superchargers out there especially with the AMG supercharger but still have not seen a final product or updates from those users. This is something I think someone should eventually tackle. It would be awesome on a E400, E420 or better yet a 500. Something to think about.
Then again, one can dream right?
I know a Guy that can build you the Header turbo/supercharger he builds most of the custom stuff for many shops and guys throughout the States,but does not like his name published...pm me an I can do a conference call it...most of the twin turbo C36 for the forum members he has done
Old 12-11-2007, 01:47 PM   #37 (permalink)
RBYCC
RBYCC's Avatar
There is a tuner trick when setting up the Split Second for a six cylinder.
Mark at Split Second told us when setting up the R4 file to set at 3 cylinder-2 stroke instead of 6 cylinder-4 stroke.
This gives a better firing pulse.
You're running a four banger?
Give Mark a call at 1-949-863-1359 you should be able to maintain a 12.5:1 under boost.
Ed A.
Old 12-11-2007, 02:26 PM   #38 (permalink)
coastline
Vehicle: Mercedes
2.2 4cyl....I just ordered a New 255 LPH pump I still think the bigger pump can't deliver enough volume,I also went for a Griffin aluminum radiator 27x17x3inch....thanks Will try Mark again.
Old 12-13-2007, 03:57 PM   #39 (permalink)
coastline
Vehicle: Mercedes
Some E220 Cabriolet Turbo Pics
Old 12-13-2007, 04:05 PM   #40 (permalink)
coastline
Vehicle: Mercedes
3 inch stailness mandrel bent exhaust-mostly_ i skimped a bit out back....
W124 E Class Picture Thread... salamanca W124 E,CE,D,TD Class 868 Today 10:29 AM
Do It Yourself (DIY) repair thread W124/300E GHM W124 E,CE,D,TD Class 1 11-11-2005 08:57 AM
pic thread W124 . continue sagamol W124 E,CE,D,TD Class 3 07-12-2005 06:47 AM
what's up with the W124 pictures thread CEorbust W124 E,CE,D,TD Class 1 12-30-2004 11:26 AM
Whats up with the W124 picture thread? Nagchampa W124 E,CE,D,TD Class 3 11-28-2004 12:58 PM
