Old 10-26-2007, 09:26 AM   #1 (permalink)
Date registered: Sep 2007
300E Engine Removal
I've been looking all over the internet for something that would tell me how to do this. I haven't been very successful so I'm asking anyone at this forum if they can point me in the right direction. I want to remove my 300E engine and replace it with another 300E engine. I just don't know where to start and what bolts to loosen. Anything would help me immensely. Thanks
KillerTomatos is offline   Reply With Quote
Old 10-26-2007, 02:42 PM   #2 (permalink)
S.M. Autoworks's Avatar
Vehicle: '92 400CE, '83 500SEC, '98 S320
Have you ever picked a motor before? Its a pretty big job for a first timer.
Above ground.....
You first need to go around all sides of the motor, and disconnect fuel lines, power steering hoses, engine harness, remove fan clutch etc, etc. Unbolt transmission dipstick from cyl head and detach kickdown cable from linkage. Also the throttle cable needs to be removed. Then, either recover the freon, or remove the a/c compressor and let it hang with manifold hoses attached.
Underside......
Remove all bolts around transmission bell housing. DON'T FORGET THE TORQUE CONVERTER BOLTS!!!!! Remove engine mount bolts.
Go back up top, and visually make sure you are free everywhere, then put a block behind the tire, and get to picking! You may have to roll car backwards a little bit as you lift the engine out. JUST BE CAREFUL!! Make sure you have a helper with you
Tip..... the front of the transmission will want to fall down when you separate from the motor. Have a block of wood, or some long bolts handy, and you can let the bell housing rest on your steering links.
Have fun
Brian
S.M. Autoworks is offline   Reply With Quote
Old 10-27-2007, 11:42 AM   #3 (permalink)
Alright I'll get too it. The engine I'm removing is already fubar, so if I mess it up no biggie. It will be good practice for the good engine I remove to put in . Thanks for the help
1988 300e front seat removal - how to? mplsdandy W124 E,CE,D,TD Class 8 05-27-2007 04:29 PM
Engine Cover Removal Help Chris_CLK430 W208 CLK Class 8 12-28-2005 08:44 PM
86 300E Exhaust System Removal phalcon51 W124 E,CE,D,TD Class 3 07-14-2005 11:32 AM
1993 300E steering wheel removal 1999valkyrie W124 E,CE,D,TD Class 0 01-21-2005 06:51 PM
Removal of rear brake discs on 300e Guest (MBNZ) W124 E,CE,D,TD Class 3 02-19-2002 09:36 AM
