» Site Navigation
» Other Sites
Old 10-01-2007, 09:21 AM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 1989 300 TE
Self level system questions 300TE
Hello fellas. I have a '89 300TE. The self leveling system seems to be not working. The car bounces harsh going down the road. Has gotten worse over the past week. Now its horrible. I think the reservoir is mounted along the inside drivers fender. If so, that is full according to the dipstick. I have read on this site it is prob. the accumulators. What to I check first? Are there any fuses or relays to check? How do I know if its the accumulators or the pump? Thanks, Mike
draglink is offline   Reply With Quote
Old 10-01-2007, 11:47 AM   #2 (permalink)
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
Its the accumulators.
Search this forum, lots of info on this...
The accumulators are divided with a rubber membrane, filled with gas on top and filled with hydraulic oil below... Thing is, your membrane is broke and the gas got away... leaving the oil in the whole accum.
As you know, the oil is an uncompressible fluid... thats why you're bouncing like there's no tomorrow
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline   Reply With Quote
Old 10-01-2007, 12:46 PM   #3 (permalink)
MiguelXJ-thanks, for the info. I had read a little by searching. Just wanted to be sure there wasnt something else. Would hate to spend the time and $ and have it be something else. Thats what it all points to. I removed the cargo plate and found the accumulators. Looks like three bolts, a large and a small hydraulic connection. Any advice to remove and replace accumulators? Thanks, Mike
Old 10-01-2007, 02:44 PM   #4 (permalink)
Another thing I noticed, after I jacked the car up to check how the accumulators where mounted, the car sits an inch or two higher. Still has harsh ride, but sits higher???
Old 10-01-2007, 03:00 PM   #5 (permalink)
MiguelXJ's Avatar
While you're under there, check the levelling valve linkage for binding.
The TE will "settle down" once you start driving.
Best advice on removing accumulators: Use LOTS od WD40, the bolts tend to rust...
Old 10-01-2007, 03:10 PM   #6 (permalink)
Thanks again, I saw that valve, looks like it had some sort of linkage that connects to the sway bar maybe? Looked OK. Thanks, Mike
Old 10-02-2007, 03:30 AM   #7 (permalink)
MiguelXJ's Avatar
[quote=draglink;2566674]Thanks again, I saw that valve, looks like it had some sort of linkage that connects to the sway bar maybe? Looked OK. Thanks, Mike[/QUOTE
Yes, it connects to the swaybar.
vacuum beam level system for euros, is it necessary? benzboy2k W126 S,SE,SEC,SEL,SD,SDL Class 4 07-28-2007 07:03 AM
oil level questions xdgr8 W124 E,CE,D,TD Class 6 06-23-2007 09:33 PM
300te 4matic Hydraulic Fluid Level RKERIVER W124 E,CE,D,TD Class 0 11-13-2006 07:13 PM
300 td level control system solid gold W123 E,CE,D,CD,TD,TE Class 1 07-19-2005 03:41 AM
A few 300te questions... AlanS W124 E,CE,D,TD Class 4 11-27-2003 08:44 AM
