How to tighten the head bolts - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-24-2007, 09:37 AM Thread Starter
bigwiki's Avatar
Date registered: Aug 2007
Vehicle: 93 300E 2.8, 79 450 SLC
My 300e 2.8 has a pretty bad external oil leak from the rear of the engine. I want to see if it can be fixed by re-torque the head bolts. How can I reach the head bolts? If I remove the valve cover, will I see the the head bolts? Or, do I have to take the whole head unit out? Just want to see how big a job it is. Thanks.
98 Toyota Sienna (boring but keeps running)
95 Jaguar XJS
79 450 SLC
93 300E 2.8 (totaled by Silverado)
bigwiki is offline
post #2 of 11 (permalink) Old 09-24-2007, 09:42 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 711 Post(s)
Remove the cam cover and the big head bolts are there for the world to see.
Good Luck,
Jayare
Jayare is online now
post #3 of 11 (permalink) Old 09-24-2007, 10:25 AM Thread Starter
bigwiki's Avatar
Good Luck,
Jayare
I don't know much about the engine. Stupid question here. Is the cam cover = valve cover? I borrow a photo from Mercedeshop below. Can I see the head bolts from this photo or I have to remove more parts?
[IMG]http://www.*****************/diy/m104headgasket/100345_4.jpg[/IMG]
Also, do we need special Mercedes tool to tighten the head bolts?
95 Jaguar XJS
79 450 SLC
bigwiki is offline
post #4 of 11 (permalink) Old 09-24-2007, 11:02 AM
Jayare's Avatar
Quoted: 711 Post(s)
You have what is called an overhead cam engine design vs. overhead valve design engine. Hence, Cam covers -- Valve covers.
You do not need any special Mercedes tool, but it would be very, very wise to have a torque wrench and know what the torque settings are for the head bolts.
Good Luck,
Jayare
post #5 of 11 (permalink) Old 09-24-2007, 11:10 AM
Jayare's Avatar
Quoted: 711 Post(s)
Wiki,
Are you sure that the oil leak is coming from between the head and the cylinder block and not just a bad over tightened cam cover gasket? If I were you, I'd clean the area with something like spray brake cleaner and see where the leak is actually coming from.
Good Luck,
Jayare
post #6 of 11 (permalink) Old 09-24-2007, 09:38 PM Thread Starter
bigwiki's Avatar
I used oil leak dye to locate the leak which is near the lower back of the engine. The oil leaks between the lower block and the cylinder block.
95 Jaguar XJS
79 450 SLC
bigwiki is offline
post #7 of 11 (permalink) Old 09-25-2007, 05:28 AM
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 2001 E320; 2002 ML500
I don't know exactly why but I read in another list that it is NOT adviseable to re-tighten the head bolts. If you still decide to do it; MAKE SURE you do use a calibrated torque wrench.
Sergio
'02 ML500
'01 E320 Wagon 4-Matic (R.I.P)
'95 E320 SE (gone)
'99 ML430 (gone)
'94 C280 (R.I.P)
'12 LR4
'02 TAHOE
Sergio is offline
post #8 of 11 (permalink) Old 09-25-2007, 05:50 AM
eric242340's Avatar
Quoted: 312 Post(s)
Re-torque the head bolts? your living in the wrong world. Try changing the head gasket
eric242340 is offline
post #9 of 11 (permalink) Old 09-25-2007, 11:14 AM Thread Starter
bigwiki's Avatar
I read from another thread that one guy fixed the same oil leak after re-torque the head bolts. If it's easy to do diy, I want to try it. I know replacing the head gasket is the long term solution but that's at least $1500. I still can't believe Mercedes cannot make good head gaskets after all these years of automotive engineering.
95 Jaguar XJS
79 450 SLC
bigwiki is offline
post #10 of 11 (permalink) Old 09-25-2007, 11:27 AM
Sergio's Avatar
My wife's '99 ML430 has over 100K miles and no oil leaks. I think MB knows how...
Sergio
'02 ML500
'95 E320 SE (gone)
'99 ML430 (gone)
'94 C280 (R.I.P)
'12 LR4
'02 TAHOE
Sergio is offline
Which is the correct way to tighten Head Bolts? Dieselbenz.info W123 E,CE,D,CD,TD,TE Class 0 08-23-2007 01:39 PM
Should I have to re-tighten the subframe bolts? ScottinSoCal R/C107 SL/SLC Class 1 02-09-2007 08:09 AM
Tighten torque for rear brake caliper mounting bolts? allerton W126 S,SE,SEC,SEL,SD,SDL Class 5 11-02-2006 05:52 AM
m102 head bolts 230emercedes General Mercedes-Benz 6 06-04-2005 07:54 AM
Head bolts 500SE hoggy W126 S,SE,SEC,SEL,SD,SDL Class 0 03-23-2003 03:25 PM
