» Site Navigation
» Other Sites
Old 09-21-2007, 02:41 AM   #21 (permalink)
Sojo300E's Avatar
Date registered: Aug 2007
Vehicle: 1991 300E, 1995 S420
Send a message via AIM to Sojo300E
it turns out that the problem was the thermostat... my dad removed it a while back and i guess that prevented pressure from building up in the cooling system.. got it replaced and now everything runs great! haha. my check engine light came back on though after just fixing it for the smog check..
Sojo300E is offline   Reply With Quote
Old 09-21-2007, 05:02 AM   #22 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Glad you found one of the problems. I am not convinced that the radiator is OK since you described that when the drain was opened, coolant trickled out instead of flowing heavily. I would also keep an eye on the coolant to make sure you don't find oil in it otherwise you will need to replace the head gasket.
Sergio
Sergio is offline   Reply With Quote
Old 09-21-2007, 05:14 AM   #23 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
One more thing: keep your dad away from the car (LOL!)
Sergio
Old 09-21-2007, 10:02 PM   #24 (permalink)
Date registered: Sep 2007
Originally Posted by Sojo300E View Post
so ive searched the forums a bit and looked for overheating issues with the 300e, and ive done a coolant flush (replaced it with the Zerex G-05), changed the oil, and o2 sensor.
The car still runs hot. I know that this car likes to run hot but my car climbs up to 110 and stays around there a lot. Sometimes it jumps to 115. With the heater on full blast it'll cool down to 100, but never really goes down past 90-95. Is there something else wrong here?
when i was flushing the coolant, i noticed that there was some white/beige creamy stuff on the cap and oil-like substance floating around in the coolant tank..
i really hope its not a blown head gasket since its so expensive to fix and im a college student. i love my benz, but i dont have the funds to fix a head gasket.
also another problem i noticed was that when i tried to flush the coolant, i opened up the little wingnut kinda thing on the bottom of the radiator (left side if you're looking at the car head on) and coolant barely trickled out at the speed of 2 drops a second.. Is it supposed to come flowing out or am i opening up the wrong part?
(sorry if this post is so fragmented)
If your is overheating for long and is still driving it, you will damage your head gasket. Oil is mix with your coolant, that is why you have white/beige creamy substance in your coolant.
A car that overheats is a sign of water pump problem. Fixing your waterpump and head gasket is the only solution to your problem. Your cylinder head may also bee warp due to your car is overheating so long.
This a expensive fix, specially for a merecedes.
RP
raul21263 is offline   Reply With Quote
Old 11-27-2007, 11:19 PM   #25 (permalink)
Date registered: Nov 2007
Vehicle: 99 E430, 2002 ML 320, 1990 300E
Maybe worth checking the electric fan is not wired incorrectly, some F$A%$^ replaced my water pump and replugged the electric fan backwards
Ranman is offline   Reply With Quote
Overheating and Engine Problem!!! AMG POWER W210 E-Class 17 06-28-2007 09:49 PM
88 560SEL Overheating Problem pathogen W126 S,SE,SEC,SEL,SD,SDL Class 15 03-04-2007 01:53 PM
overheating problem BenzNoob W210 E-Class 7 01-12-2006 02:20 PM
190 e 2.6 overheating problem tito General Mercedes-Benz 4 08-26-2005 01:28 PM
overheating problem Ted G-Class 13 10-01-2001 08:16 AM
