» Site Navigation
» Other Sites
Old 09-14-2007, 08:44 AM   #1 (permalink)
Date registered: May 2005
Question camshaft: best factory cam?
Is there any factory cam used in the M103 engine that is better for power than others? I currently have three to chose from, my original and those on the rebuilt heads on the bench (not there to pull the numbers at the moment). I'm aware that the manual trans cars had slightly different timing on the intakes. Or, alternatively, would the power difference be so small as not to be noticed? My stock USA 1987 300E (without factory EGR) runs rather well, but while its apart... Thanks!
Hanno
83 280SL 5 spd. (Euro)
86 190D2.5 5 spd
87 300E, 5 spd. conversion
88 300E, parting out
79 6.9
95 E320 wagon
95 E320 sedan (with new engine harness)
hanno2s@verizon.net is offline   Reply With Quote
Old 09-14-2007, 09:47 AM   #2 (permalink)
RBYCC's Avatar
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL, 94-E320 CAB
Not really...all factory cams are basically the same. !!
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
camshaft, camshaft bearings, and rocker arms lyrics10 W126 S,SE,SEC,SEL,SD,SDL Class 5 08-24-2007 04:14 PM
Cam oiler help please (No lift cam...) DarkOneSK W126 S,SE,SEC,SEL,SD,SDL Class 8 03-10-2007 05:47 PM
camshaft lyrics10 W126 S,SE,SEC,SEL,SD,SDL Class 20 12-21-2006 04:39 PM
Factory Back-up Cam!! UncAl W163 M-Class 4 09-17-2004 10:59 AM
Factory Black Cam Covers? Vincent W126 S,SE,SEC,SEL,SD,SDL Class 1 02-10-2004 04:24 PM
