Old 09-13-2007, 12:46 PM   #1 (permalink)
dbow2000's Avatar
Date registered: Aug 2006
Vehicle: '94 E320 (154k) '99 (120k) CLK320(sold) '04 Mazda 6s (sold) '86 Merkur XR4TI (sold)
Auxiliary Fan help
I was at the light today and heard a loud squealing sound. I opened the hood and it was the fan on the front left side behind the horns. I turned the car off and hand turned the fan a few times and you can hear the squeak. I can't see a good way to get in behind there to get some lubricant on it or replace it if necessary. Anyone had this problem before? What's the secret to fixing this?
dbow2000 is offline   Reply With Quote
Old 09-13-2007, 01:21 PM   #2 (permalink)
dbow2000's Avatar
Possible Solution
Here's a possible solution that I found on Mercedesshop.com
Let's change the Aux Fans on a W124! - ShopForum
auxiliary fan - part II andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 11 05-12-2007 01:41 AM
When should the Auxiliary Fan cooling fan come on? panamacolin W123 E,CE,D,CD,TD,TE Class 22 05-09-2007 07:25 PM
auxiliary fan oldcarpappy W123 E,CE,D,CD,TD,TE Class 1 09-17-2004 12:39 PM
Which is the Auxiliary fan??? kytrex W201 190E, D-Class 1 07-15-2004 05:41 PM
AUXILIARY FAN SPEED ~R~ W124 E,CE,D,TD Class 1 03-11-2004 06:24 PM
