» Site Navigation
» Other Sites
Old 09-11-2007, 02:38 AM   #1 (permalink)
almomen
Date registered: Sep 2005
Send a message via MSN to almomen
suspension
hi
i installed eibach springs on my e320 1995 and they look very low and all pump in city i hit
i wanted the car to look lower than the stock cars and just as high as the amg version , although all rubber rings i used to get the front of the car high but no help
if any one can help me in this, i live in middle east
almomen is offline   Reply With Quote
Old 09-12-2007, 06:26 PM   #2 (permalink)
gregs210
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, almomen, welcome to the forum.
Are you sure the springs were for your specific model? If so then did you put the largest spring pads on them?
If you have the right springs and the largest pads, the only other thing you could do would be to install those crummy little spring compression/expansion inserts. I've no idea where you might find them in the ME, here the chain auto parts stores carry them. JC Whitney sells them here, I don't know if they do international, but the one type looks like this:
Last idea I'd have would be to have a ring cut off of your stock springs and then put those back in. Hope it works out for you.
Take care and enjoy the ride,
Greg
Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 3 07-28-2007 03:56 PM
Can you change the air suspension from a V-Class to Spring suspension? kimberly General Mercedes-Benz 2 11-16-2006 02:35 AM
Can you replace the self-leveling suspension with a regular suspension 300e_4matic W124 E,CE,D,TD Class 10 12-21-2005 12:14 PM
What is difference between normal suspension and super suspension Gatecrash R171 SLK Class 0 04-06-2004 09:10 AM
How much suspension travel is there on a SLK32 with OEM suspension; front & rear? Beng R170 SLK Class 1 01-23-2002 09:33 PM
