» Site Navigation
» Other Sites
Old 09-08-2007, 01:16 PM   #1 (permalink)
petermerle's Avatar
Date registered: Nov 2002
Vehicle: 1982 300GD *2
300D engine vibration under load
I have just got myself a good condition 300D W124 non turbo and find it very irritating to drive as the engine exhibits a strong vibration around 1500 - 1600 rpm when under load . Is this 'normal' for this engine? My OM617 's don't show this behavior.
Peter
http://autos.groups.yahoo.com/group/SAGW/
W460.332 300GD *2
W123.130 300D
W124.130 300D
W120.110 180D
petermerle is offline   Reply With Quote
Old 09-08-2007, 09:18 PM   #2 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
howzit china!!!!
OM 617s arent in W124s.
only 601, 602, 603, 604, 605, 606. 1, 2, 3 were early single cam diesels that came after 616 and 617. 4, 5, 6 were twin cam multi valve engines IIRC.
as for the question at hand, try the motor mounts. including the gearbox mount.
go boks.
edit. just realised you didnt imply anywhere that you had 617
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 09-08-2007, 10:23 PM   #3 (permalink)
petermerle's Avatar
I was referring to the OM 617's in my W460.332 and W123.130's - I have 3 OM617 engines and one OM603 in the W124.
PEter
Old 09-09-2007, 07:11 PM   #4 (permalink)
Date registered: Jul 2007
Vehicle: 1992 300D 2.5 Turbo
It's not normal for the engine. Do you get the same vibration when revving the engine in neutral? If not, the problem is more likely stemming from improper alignment or wheel balance, or possibly driveshaft vibration. If it does, it could be as simple as motor mounts. PM me if you like.
Romanow is offline   Reply With Quote
Old 09-11-2007, 12:10 PM   #5 (permalink)
petermerle's Avatar
Does your 124 have a propshaft vibration damper just behind the front flexable coupler. My mechanic tells me I should have one even though the EPC says its not required.
Peter
Old 09-11-2007, 07:04 PM   #6 (permalink)
Date registered: Aug 2007
I think that vibration is normal. my uncle's 300d has the same problem. .
Cool Benz blog.
Click me
benzyfreak is offline   Reply With Quote
85 300D with a vibration around 35 mph 67300se5spd W123 E,CE,D,CD,TD,TE Class 18 08-10-2007 04:36 AM
Load noise from the engine Nubian Benz W163 M-Class 6 10-09-2006 06:08 PM
engine misfire at high rpm and load brian/ont W163 M-Class 4 01-10-2004 02:52 PM
Vibration under load at very low speed petermerle G-Class 16 08-12-2003 07:37 AM
Heater comes on under engine load dfleischli W201 190E, D-Class 3 09-09-2002 10:46 PM
