Old 09-07-2007, 07:57 AM   #1 (permalink)
Date registered: Jun 2003
Vehicle: E280 W124
Problems Starting
Hi Everyone,
I've got a weird problem with my W124 E280 (1994).
After the engine has been running (lets say warmed up for a while or has been driven for a while) and then the ignition is switched off, when I try to restart immediately or within a minute or so, the engine won't run. You can hear the starter motor but nothing is happening. However, after waiting a couple of minutes, and then restarting the engine will start with no problems. I've changed the following items but it still has this problem.
- Fuel Pump
- Fuel Pump Relay
- Oil Filter
- Fuel sensor
Does anyone have any ideas what could be causing this problem, me and my mechanic friend are stumped.
Car has only travelled 103,000 km, I live in Perth which has a moderate Mediterranean climate ie between 0 Degrees Celcius to 40 degrees C
Cheers
Jon
happy_jon is offline   Reply With Quote
Old 09-07-2007, 08:30 AM   #2 (permalink)
MercedesJoe's Avatar
Date registered: Aug 2007
Vehicle: 1994 E420
Im having the same problem with my E420. the starter turns but doesn't engauge. I wait and it starts right up. I was adviced the starter was going bad. I'm changing it this weekend and I'll repost on monday with the results.
MercedesJoe is offline   Reply With Quote
Old 09-07-2007, 08:56 AM   #3 (permalink)
Vehicle: E280 W124
Cool, look forward to hearing the results. How much is the starter motor in the states? You buying an original from the dealer or an OEM?
Cheers
Jon
Old 09-07-2007, 09:06 AM   #4 (permalink)
Vehicle: 1994 E420
Bought from a parts dealer who had a bunch from a mercedes bone yard. I paid 25$ for mine. But that was because he had a bunch I'm not sure how much a new one cost. Take a look on the web.
Old 09-07-2007, 10:02 AM   #5 (permalink)
Are the sparks present, you need a spark detector, available at parts store for less than $10.
Saumil is offline   Reply With Quote
Old 09-07-2007, 11:20 AM   #6 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
jon,
I am reading your question as the car not starting ie. internal combustion. If the engine is turning over and you aren't getting "fire", the problem isn't the starter. Mercedes Joe has a bendix problem with his car if he hears the starter spinning and the motor isn't turning over.. Your problem is completely different than his..
Do the simple stuff first and see if you are getting spark to the plugs in the sitituation you initially described. Let us know and we will go forward from there.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
Old 10-02-2007, 10:12 AM   #7 (permalink)
Vehicle: E280 W124
Problem Mostly Fixed
Hey Everyone
I've figured what the problem was. It was in relation to the wiring loom and wires around the top of the engine. They needed to be redone. I think the heat in Australia has deteriorated them significantly.
The car is heaps more reliable now. Will fire most of the times, except on the odd occassion, which may suggest some other wires may be fried. Fun fun fun
Thanks for all your input.
On a brighter note, after changing all those fuel sensors, relays etc, my car is actually driving more efficiently.
Cheers
Jon
Stored 1993 S420 has fuel problems-Gives sudden starting problems-solution needed heartmd W140 S-Class 15 12-09-2007 01:45 PM
Starting Problems saabcm W140 S-Class 6 03-10-2007 01:26 PM
Problems starting.... DarkManX4lf W123 E,CE,D,CD,TD,TE Class 13 02-20-2007 05:10 PM
Starting problems... please help Marbus W124 E,CE,D,TD Class 1 11-14-2005 09:30 AM
anyone have starting problems? My car died twice today after starting... cgeorge430 W163 M-Class 10 08-03-2002 10:57 PM
