» Site Navigation
» Other Sites
Old 09-06-2007, 03:07 PM   #1 (permalink)
Handy930T
No Cruise Control...., Now What?
1991 300E 4matic. 105K Cruise quit. Was OK. Then very erratic. Then nothing. I pulled out the control modual board. All looks OK. No discoloration no sign of bad connections. What is the next step short heading to a dealer?
Handy930T is offline   Reply With Quote
Old 09-06-2007, 05:19 PM   #2 (permalink)
Jayare
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 90 300CE, 92 300E (sold), 93 400E, 02 Olds Aurora
Handy,
The problem with the cruise control amplifier isn't visable from any outside connection. The problem is inside the unit. If you know your way around circuit boards and know how to solder, take the unit apart and re-solder all the connection points on the board. Other than that, purchase a new unit and they are on the pricey side. You can also just keep a steady foot. My coupe is the easiest car I've ever owned to keep at a steady speed.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
cruise control floman W201 190E, D-Class 2 04-17-2006 02:52 PM
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK Class 42 01-15-2006 01:37 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
Help with cruise control Miked619 R170 SLK Class 12 01-24-2005 01:05 AM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 09:34 AM
