» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 09-05-2007, 08:35 PM   #1 (permalink)
hchau5
Date registered: Apr 2007
Vehicle: 1993 Mercedes 400E
windshield wiper motor
im having problems with my windshield wiper ... the wipers does not wipe that well .. when i say it doesnt wipe that well i mean my car only has one wiper and it usuallly does the upside W movement for some odd reason it does the upside down U and the wiper blade would hit the side of my the windshield touchin part of the rubber that insulates the windshield to the car ... any idea? ... i think there's something wrong with the motor ... the motor works but not properly ...
hchau5 is offline   Reply With Quote
Old 09-05-2007, 09:07 PM   #2 (permalink)
Uboater
Date registered: May 2003
Vehicle: E320 wagon
hchau5
1. Your blade could be shot if it hits the rubber edge . I should clip in place or have a plastic pin to hold it.
2. The cam slide under the hub cover could be loose . If you have loud clicking
metallic sounds when the motor runs / wipes , I bet it needs lube or screws tighten on the side guides.
Try cheap first = new wiper blade $5 -$20
Uboater
Uboater is offline   Reply With Quote
Old 09-06-2007, 04:58 AM   #3 (permalink)
hchau5
I already bought new wiper blades and it still rub against the rubber edge ... im for sure the windshield motor ... because when the blade move it doesnt go up and down ... it just goes str8 over to the other side like a U ... u get what im saying? .... some metallic sounds ...should i check the screws or lube the motor
Old 09-06-2007, 08:12 AM   #4 (permalink)
Inline6
Inline6's Avatar
Date registered: Aug 2006
Vehicle: '87 260E, '97 Nissan VQ Cefiro
A friend had this situation a month ago. Culprit was the gear between the wiper arm & motor that makes it go up & down. You have to pulldown the wiper arm to access the gear.
Inline6 is offline   Reply With Quote
Windshield wiper motor? rellascout W126 S,SE,SEC,SEL,SD,SDL Class 9 11-10-2006 11:19 PM
Windshield wiper motor XIGNSX W210 E-Class 2 10-03-2006 07:55 PM
Windshield wiper motor SilverBenz W210 E-Class 0 08-06-2006 04:18 PM
Windshield Wiper Motor otiswesty G-Class 3 12-04-2005 09:19 PM
Windshield wiper motor-replace? hawg03 W202 C-Class 6 10-27-2005 06:14 AM
