» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 09-05-2007, 06:22 PM   #1 (permalink)
denorea
500e rear end
Im planing on going for more horse power this fall . I have a 1990 300ce.A buddy of mines has a complete 92 500e rear end with calipers/struts/rotors and and all.Im planning on dropping it in this weekend.Anything to look out for.What are the benifits of this rer end if any?
denorea is offline   Reply With Quote
Old 09-05-2007, 07:00 PM   #2 (permalink)
mcbear
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Well, unless your CE has SLS the struts for the 500E are part of a SLS [Self Leveling Suspension] which is going to require an good amount of plumbing work, replacement of your power steering pump with a model that addresses the SLS.
You are also going to get a numerically higher rearend which is going to change all your shift points and bump up your gas usage by about 20%.
Third, the ride height is going to be different with the 500 rear end and there were extra suspension pieces associated with the 500 that is not on the stock 124 chassis cars.
It will all bolt together but is going to take a bunch of work. Keep us posted as to how it went together and what all was required.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2000 S500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 09-05-2007, 07:17 PM   #3 (permalink)
denorea
Great , Thanks for your wisdom. My car doesnt have sLs.So im not going to convert it to that system . So for that instance do I just replace the 500e strut with a regular non sls strut. Also , is this a strong rear end. What about the ASR ?
Old 09-05-2007, 09:18 PM   #4 (permalink)
mcbear
mcbear's Avatar
Vehicle: 500Es
You will have to disable the ASR also as you don't have it programmed into the rest of the system. That should be a simple unplug if I am not mistaken [I have not tried that type of disconnect of the ASR].
As for the struts, I think you are going to need more than just the strut. Call Luke at Tire Rack and ask him about converting a 500E rear end to Bilstein without SLS. You might have to get springs also. I can't remember at this hour.
And yes, it is a strong rear end. I am on a group of 500E only guys and some tend to do pretty much everything to their cars and I have never heard of a rear end going out.
500E vs 400E Front End Differences, some observations... mcbear W124 E,CE,D,TD Class 0 08-11-2007 04:01 PM
500e rear seat removal tobyd W124 E,CE,D,TD Class 0 01-26-2006 01:08 PM
560sec rear leveling and rear end brake fluid change 560sec_vroom The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 11-08-2005 01:45 PM
''DEWDALTZ can you show me a picture of your rear view camera from the rear end of the car alroumi W163 M-Class 3 01-26-2005 07:32 AM
Best $$ Rear Hydro shocks 500e? Fireice W124 E,CE,D,TD Class 0 11-29-2003 07:04 PM
