» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 09-04-2007, 02:06 PM   #1 (permalink)
vili1982
vili1982's Avatar
Date registered: Jan 2005
Vehicle: 95 E320 Coupe, Diesel Golf
Send a message via MSN to vili1982
Headlight question
Hey guys, one of my lights the passenger side is throwing off too much power basically the bulb is much brighter than the left driver side, is this normal, is the right one OK? or is the left one not throwing enough power???
Is there a way I can check? What is the normal voltage they are suppose to recieve?
anyone?
Thanks
In the world of roads, there are those who travel and those who own it. The choice is yours.
95 Coupe
vili1982 is online now   Reply With Quote
Old 09-04-2007, 02:38 PM   #2 (permalink)
RBYCC
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL
anyone?
Thanks
Bulbs/lamps are rated at a nominal 12 volts.
When you are running you could possible supplying around 13 to 14 volts.
Look more to the dimmer bulb/lamp to determine the problem.
Switch bulb/lamp side to side to determine if it's a failing lamp.
If you get the same result after switching the lamp/bulb, then start looking at your connections and wiring.
Clean all the connections thoroughly and burnish the contacts, do this not just at the lamp connection , but back through any connectors in the harness to the power source.
Post back after you try the above basic steps.
Ed A.
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 09-05-2007, 10:33 AM   #3 (permalink)
vili1982
vili1982's Avatar
Hey thanks for your reply, but I found the problem, the voltage supplied to both headlights is teh same, the problem was my right headlight was tilted up more thant the left which kidn of gave it a more glare bright spot, when I adjusted to the same level as the left one it now looks the same.
Thanks.
Another headlight question JoeBlow W163 M-Class 5 02-12-2007 02:55 PM
Headlight question mtimmy W208 CLK Class 8 03-31-2006 12:54 PM
Headlight question! Kiriller W203 C-Class 9 11-14-2005 03:50 PM
headlight question teflon_don W163 M-Class 10 06-01-2005 12:10 AM
headlight question Iphixit W210 E-Class 10 07-21-2004 12:33 AM
