» Site Navigation
» Other Sites
Old 09-03-2007, 01:09 PM   #1 (permalink)
Date registered: Jul 2005
Vehicle: 1992 300E 4Matic
Rear door panel removal
Another Labor Day spent laboring...
I am in the midst of removing the rear driver side door panel of my 92 300E 4matic. I have read the various posts (here, mercedesshop.com and mbworld.org) and all have been extremely helpful. However, I still have one question.
I have removed the ashtray from the door (the part where the ashes go) but do I also need to remove the housing that holds the ashtray, or does that come out with the door frame?
Thanks!
iragreenstein is offline   Reply With Quote
Old 09-03-2007, 09:23 PM   #2 (permalink)
merc-one's Avatar
Vehicle: 1988 300E
no need to touch the ashtray. it comes out with the door panel.
i just did this myself as i was replacing the check strap on the right rear door. i hate that feeling that your about to break something when you're puling things like door panels off. remove the light on the bottom of the door panel. pop off the cover surrounding the door handle and window switch. pop out the door handle and remove the bolt just in front of the switch. remove the one screw and plastic surround by the latch. then just run your fingers all the way around the edge of the sides and the bottom to break the light seal of glue, and slide the whole thing up and it should just pop off. oh, first uncrew the door lock pin.
refitting is a bit of a PITA. it's one of those things that you feel like you need four hand for, but you'll get it.
1988 MB 300E
1988 Saab 900s
2000 Aprilia Pegaso 650
merc-one is offline   Reply With Quote
Old 09-04-2007, 04:52 AM   #3 (permalink)
Thanks for the response. Unfortunately, my experieces with this car is that when I feel i'm about to break something, i do.
I'll give it a shot this evening.
rear door panel removal mountainredneck W124 E,CE,D,TD Class 11 04-19-2007 06:01 PM
97 V230 rear door inner door card/panel removal ziras V-Class 6 02-27-2007 01:01 PM
rear door panel removal? imwalkin W163 M-Class 2 06-23-2005 02:42 PM
Rear Door panel Removal SethMac86 W124 E,CE,D,TD Class 7 04-10-2005 01:58 PM
Rear door panel removal? ChristopherGeorge G-Class 2 12-13-2002 01:08 PM
