Try searching for compressor sensor, see if anything comes-up. Or Nippondenso, then look under parts. Also try A/C shops for unservicable compressors but with working sensors.
The sensor cuts-off the compressor when the engine speed is very high. I noticed this when doing 120-130 from time to time.
Have you tried using a different Klima relay just to test if yours is still ok?
The sensor you are concerned about is called a "speed sensor" It does exactly what Inline6 states.. In Clearwater FL, there is a company "Chilly Bear". They have the sensors and replacement compressor if needed. Look them up in the phone book.
Good Luck,
Jayare
Jayare thanks ALLOT !!
I was able to go there today, and get the part for a mere 50$
Im getting it put in over the weekend, so Ill let everyone know how it goes.
Thanks again everyone for your input.
