» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 08-30-2007, 06:28 AM   #1 (permalink)
odida
odida's Avatar
Date registered: Aug 2007
Vehicle: 1988 260e, 1989 Saab 9000CD
Talking Excited newbie with questions
Just bought an 89 260e and I'm so excited. She runs smooth and the interior is immaculate however i have a couple of questions
1. The timing cover is leaking how serious is that?
2. how much power does a catless 260e make? The sites i have visited range from 158 to 170 bhp
3. The idling is above 1400 when started from cold but drops to 1000 when warm, is this normal?
4. There is a a noticable thunk when shifting from park to drive how serious is this?
Looking foward to your replies thanks.
odida is offline   Reply With Quote
Old 08-30-2007, 08:57 AM   #2 (permalink)
merc-one
merc-one's Avatar
Vehicle: 1988 300E
1) i think the gasket for the timing cover leaks on every single one of these motors. mine does. it's an easy fix, so if it's a lot of oil just do it. i've been putting it off until i get around to changing my timing chain.
2) no idea. someone else will know this
3) this is not normal. i would look for vacuum leaks first
4) when was the last time the trans fluid and filter were changed? again, it's an easy job, but this one is messy when you drop off the cover to drain the old fluid. also check the flex discs on the drive shaft.
have fun.
1988 MB 300E
1988 Saab 900s
2000 Aprilia Pegaso 650
merc-one is online now   Reply With Quote
Old 08-30-2007, 11:17 AM   #3 (permalink)
mcbear
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Hi, welcome to the board. Go ahead and fill out your profile so we can know where you are from.
Regarding you Idle question, if you are in the US and the CATS are removed it is possible that they also removed the air pump. This will cause the computer to idle very high and rich at the start of a run cycle. If that is the case you most likely are not getting great gas mileage also.
If you are not US, I agree that vacuum is a likely culprit and is faking the computer out. Also check your O2 sensor that is sending information to the computer.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2000 S500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 08-30-2007, 11:46 AM   #4 (permalink)
Sergio
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Looking foward to your replies thanks.[/quote]
This MAY be serious. Have someone inspect the flex discs for cracks, particularly the front one, immediately. If it breaks it can cause other damage.
Sergio
Sergio is offline   Reply With Quote
Old 08-31-2007, 05:41 AM   #5 (permalink)
odida
odida's Avatar
I am having a full service done tomorrow including the gearbox so i will have them check the flex discs. I'm in Kenya so i guess its probably a vacuum leak thats responsible for the high idling. Thanks for all the advice i will update you after the service is done. Cheers
Old 09-05-2007, 12:09 AM   #6 (permalink)
odida
odida's Avatar
Did the service and discovered the gearbox fluid was down to less than a litre! i changed the fluid, gasket and filter. Shifting is much better now except for reverse which has a slight(3 sec) delay before engaging with a jerk. i suspect the clutch was damaged when the atf fluid was low.
The uneven idle however got worse after the service and morphed into a hard start problem. Now when I crank it I have to give it some gas before she fires. A vacuum leak check (pouring a little petol around the suspect areas) revealed a vacuum leak under the fuel distributer. How to fix this? Also the entire exhaust system is shot. would this contribute to the uneven idle?
Old 09-05-2007, 07:59 AM   #7 (permalink)
merc-one
merc-one's Avatar
Vehicle: 1988 300E
exhaust shot - how?
I suppose if you lost some baffles in one or both mufflers it could cause problems with back pressure (either too much or too little), but I don't really know.
Old 09-05-2007, 11:22 PM   #8 (permalink)
odida
odida's Avatar
Shot as in full of holes and leaky as a sieve. Am replacing the whole system from manifold to the end over the weekend, will see it makes a difference. Not sure what to do about the vacuum leak though.
ML Newbie questions KyGuy W163 M-Class 3 02-12-2007 09:13 PM
Newbie w/ Questions miamichic W220 S-Class 5 01-17-2007 05:48 PM
2 newbie questions SLKRoadster99 R170 SLK Class 6 04-30-2005 06:47 AM
Newbie questions bodypainter R170 SLK Class 4 03-14-2004 07:35 PM
Newbie with a few questions... 300E W124 E,CE,D,TD Class 8 06-18-2003 08:51 AM
