Old 08-19-2007, 02:44 PM   #1 (permalink)
Date registered: Aug 2007
260E Diffcult to Start
Hi,
I have a 260 E 88/89 model year , which when warm is very difcult to start, from cold there are no problems and it starts fine.
When the engine runs it idles ok and the power and general runing are ok . But when the engine is warm and you then swtich off the engine for a short while ( no set time ) when you come to restart then the engine is very reclutant to fire up, when it does it seems to be over fueling.
does anyone have any advice?.
Could you provide me with coolant temp sensor and airtemp sensor readings resitantance / ohms, also could you please inform me when the CO adjusting screw is fot the 260 engine as I have a chance to check and adjust the CO content .
Regards.
Phil.
Vida is offline   Reply With Quote
260E wont start reinholdt W124 E,CE,D,TD Class 5 07-09-2006 03:47 PM
89 260E Won't Start Geeky1 W124 E,CE,D,TD Class 3 04-12-2006 10:41 PM
A very diffcult question 03ML320 W163 M-Class 2 05-19-2003 10:04 AM
260e low idle stalls on first start Guest (MBNZ) W124 E,CE,D,TD Class 0 03-14-2002 05:57 PM
260E has sparks but will not start Guest (MBNZ) W124 E,CE,D,TD Class 2 08-31-2001 09:33 PM
