» Site Navigation » Other Sites
08-14-2007, 04:06 PM
#1 (permalink )
Date registered: Mar 2007
Vehicle: 87 300D Turbo, 93 300D Turbo
What tool do I need to remove the 8 axle bolts connecting axle to the differential? I need to replace my axle and I heard that the bolts holding the axle to the differential are a special type.
What kind of bit is needed and what size?
08-14-2007, 07:25 PM
#2 (permalink )
Date registered: Sep 2002
Vehicle: 1995 E320
Triple square hex size 10 (I believe)
Sergio
08-15-2007, 04:13 AM
#3 (permalink )
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
Yeah, I think Sergio is correct and those bolts are a real PITA to remove. Access is very difficult.
08-15-2007, 05:27 AM
#4 (permalink )
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Springman,
The hex bit that is needed is a 12 point, 10MM. The exhaust will need to be dropped (take off the hangers) if you are working on the drivers side. The giant nut on the end of the axel is a 30MM.
Good Luck,
Jayare
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Axle boot replacement tool Trevor Sarty W123 E,CE,D,CD,TD,TE Class 0 04-11-2007 04:56 AM Axle shaft bolts Sergio W124 E,CE,D,TD Class 0 11-18-2006 02:47 PM Differential / Axle bolts? mramay W126 S,SE,SEC,SEL,SD,SDL Class 33 11-25-2005 11:09 PM Axle Carrier Rack bolts ae86pwr W163 M-Class 0 10-06-2004 06:59 PM Rear Axle Differential Identification. sss11 W126 S,SE,SEC,SEL,SD,SDL Class 3 07-24-2004 04:59 PM
