» Site Navigation
» Other Sites
Old 08-14-2007, 03:01 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: '90 300E Black/Tan
90 300E serious miss problem - help
OK, so I replaced plugs, cap, rotor, wires and the miss persists. Cylinder 3 appears to be dead. It is getting fuel and spark, but compression is zip, so I assume since this problem went from a minor intermittant rough idle that cleared up to a full time miss that doesn't, that a valve is probably stuck open. May be a piece of carbon. Rebuilt heads look like $940 plus shipping if I reuse my cam/lifters/rockers, $400 to $500 of that being a core charge, so ~$500 to fix.
Before I go that route, what other options might be available? I remember seeing something about a product that can clean the carbon out? Anyone know about that ? Other options? Not sure if I have a local shop that could do a refurb, or if it would even be worth it.
All input appreciated....especially if you have already been through this one....
Andy_M is offline   Reply With Quote
Old 08-14-2007, 03:38 PM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
I'm going to wager this is more then a stuck piece of carbon.. Who is doing your head?
I'm thinking more along the lines of broken or cracked valve..
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is online now   Reply With Quote
Old 08-15-2007, 05:32 AM   #3 (permalink)
Jonathan
Probably will buy a rebuilt head. There is a couple of places in California (autoshoppingcenter ) and
Mercedes Rebuilt Engines
that have them.
Out of curiosity, what makes you suspect a broken or cracked valve ?
Old 09-02-2007, 07:36 PM   #4 (permalink)
Date registered: Sep 2007
I also have a 91 300 E with same symptom. 185 psi all cyl. except #3 which is 0.
If anyone has a solution short of head rebuid or major work, I'll try. otherwisw car is too old and banged up to do major engine work.
Don
shavereng is offline   Reply With Quote
Old 09-03-2007, 09:19 AM   #5 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
we used to pour a small amount of water or brake fluid into the inlet manifold as the engine was being revved. not a lot, barely a trickle.
old school carbon removal. dont even know that it worked but thats what we did.
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 09-04-2007, 08:57 AM   #6 (permalink)
Don
In my case #3 turned out to have a chipped valve. No damage to piston at all but valve was chipped. Also had traces ov valve blow by in the intake tracks of the 2 other cylinders with lower compression than the others. Valve job most definately indicated. Springs all tested good. Head being completely redone by a local shop for a very reasonable price, so I am not going the pre-rebuilt head route. Should be reassembling this week.
Pulling the head was not especially difficult.....time consuming, but not terribly difficult.
Andy M
'90 W124 300E
'03 Porsche 986
Low RPM miss- Problem solved-Many Thanks AlaRonnie R/C107 SL/SLC Class 0 08-02-2007 04:27 AM
Miss firing problem 2.6 ricehunter W201 190E, D-Class 6 04-06-2006 11:46 AM
300E problem matteus W124 E,CE,D,TD Class 2 08-04-2003 01:33 AM
300E Idle problem & A/C vent Problem Guest (MBNZ) W124 E,CE,D,TD Class 6 07-26-2002 10:02 PM
300E HESITATION/MISS UNDER ACCEL. Guest (MBNZ) W124 E,CE,D,TD Class 2 05-11-2001 02:25 AM
