» Site Navigation
» Other Sites
Old 09-10-2007, 03:07 PM   #11 (permalink)
Deanyel, you are correct. I cannot check codes. It appears there are 3 or 4 wires connected to the clutch. If I pull the connector and jump with a 12v line which connection point do I use? Thanks
Handy930T is offline   Reply With Quote
Old 09-10-2007, 06:53 PM   #12 (permalink)
smokiesman's Avatar
Date registered: May 2004
Vehicle: 95 E 420
Ok! Going through simular with my E420! If compressor does not run you are genealy low on freon! Hook up a gauge to the suction or low side and if you have less than 20 lbs compressor is not going to run!!! Find the reciever drier down in the front corner by the drivers side headlite and you will see a pressure switch at the TOP and side of drier THE BIG SILVER ONE cross those 2 wires and the comressor should pull in!! If you system is short cycling that is the compressor running a few seconds and shutting off means the system is low on freon. If you charge up the system and it loses pressure after a short time you may have a bad evap. I ran some super seal in mine and I think it plugged the hole but I had other problems mostly moisture in the system and I am sure it crapped out the drier. I am also replacing the expansion valve on the firewall. When my parts get here I will vac down the system replace the freon and cross my fingers!! I fig that I would spend a couple hundred bucks and try and fix it before I had to shell out 3 grand to put in new evap. Wish me luck!! I have a new E320 drier for sale if anyone needs one CHEAP!!
Smokie
95 E420 BigBlue
500E Sway bars
2001 C Class 16 in. Rims
KYB Struts and shocks
Rear spoiler
JVC EXAD Mp3 player
JVC EXAD GPS
Wald Front Spoiler
Bigred 99 F250 Powerstroke
American Stitches Wheel
Assorted Bling
smokiesman is offline   Reply With Quote
Old 09-10-2007, 07:01 PM   #13 (permalink)
Date registered: Jul 2004
Anyone can check codes - all you need is about $10 worth of parts from Radio Shack. You have a private message on this. If at the compressor you have a red/blue, a white/blue and a blue/green - the blue/green is the 12 volt power.
deanyel is offline   Reply With Quote
Old 09-12-2007, 12:26 PM   #14 (permalink)
I didn't try the jump to the clutch as there were several wires going to the connection. Which one would control the clutch? Thanks again.
Jolt when Reverse is Engaged anythinggoes W140 S-Class 12 05-25-2007 11:08 PM
How you get engaged...... Jakarta Expat Off-Topic 0 03-13-2007 12:54 AM
s c clutch is permanently engaged ag243w R170 SLK Class 8 08-04-2006 06:19 AM
my sc clutch is permanently engaged? ag243w Off-Topic 7 04-12-2006 07:34 PM
Supercharger engaged at cold startup RobW R170 SLK Class 7 01-16-2001 12:55 PM
