» Site Navigation
» Other Sites
Old 08-02-2007, 01:33 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 92 300e w/130k, black on black
had a cool idea
i was thinking of hardwiring a switch for the kickdown button under the gas pedal so i could kickdown a gear without having to floor the accelerator. would be nice when you are dipping in and out of turns, you could hit the switch prematurely so you wouldnt have to wait for the gear to kickdown when you are half way through a curve.
anyone done this? anybody have some schematics? i dont think it would be very hard.
92 300E with 145k, charcoal on black interior
eibach pro kit with bilstein HDs
17" amg knock-offs powder coated flat black
35% tint
westonian is offline   Reply With Quote
Old 08-02-2007, 02:22 PM   #2 (permalink)
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL, 94-E320 CAB
Why not just downshift???
"Kicking down" or "downshifting" while in a curve is not a safe or accepted performance driving technique.
You should be in your lower gear and have your braking complete as you enter the curve and accelerate out in that same gear as you exit the apex of the curve.
To do other wise ( down shift or braking )will cause an abnormal weight shift and upset the cornering balance that you try to maintain.
Can cause some real problems driving that way !!!
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 08-02-2007, 03:48 PM   #3 (permalink)
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Might not be so much fun in the rain.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2000 S500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 08-02-2007, 05:33 PM   #4 (permalink)
i was hoping this would be less about driving technique and more about actually figuring out a way to do this. RBYCC, you are right. i was just trying to throw out an example that it could be useful in.
my point is that i dont like to screw with the shifter on an automatic, especially on a benz. its clunky, wears out shifter bushings, and i feel foolish trying to shift gears in my auto like it was stick. if i wired up a little button or switch i could just flip it when i am anticipating the need to shift down, instead of waiting for the laggy downshift. ever been going up a hill, not needing to give it more gas but just trying to get it to downshift? sometimes its pretty stubborn. thats what im trying to aid here.
i just wanna know if anyone might have some tips or experience with doing something like this?
and btw mcbear, no shit it wouldnt be fun in the rain. thats why you dont drive like that in the rain.
Old 08-02-2007, 09:24 PM   #5 (permalink)
RBYCC's Avatar
Nothing wrong with manually shifting.
I do it all the time in all my vehicles from a paddle shift six speed 400HP C6 to my G55.....don't do much with the C43 as my girl friend drives it.
I've had my 300CE since purchasing it new in may of 1988.......even with the recent addition of a whole lot more torque, my driving style hasn't changed.
I prefer to engine brake the car when I feel like a "spirited" drive.
Also don't like to "kick down" as it is more brutal then taking control yourself at a better RPM and gear to maximize acceleration.
If your transmission is in top shape you shouldn't get the "lag' you describe.
I've found in nineteen years of ownership that the transmission is above average when it comes to response time.
How fast it shifts has to do with throttle pressure, you might want to have your trans checked out because if it lags using the shifter it probably will lag on a kick down.
Old 08-03-2007, 12:34 AM   #6 (permalink)
Date registered: Mar 2006
My Personal Advice is not to go for an External Switch. It might cause problems with the Shifter in the future and having problems in a MB are very costly and hair raising. It is also very dangerous.
supercars is offline   Reply With Quote
Old 08-03-2007, 02:21 AM   #7 (permalink)
you are probably right about the tranny not being in very good shape. the people that owned the car before never had the fluid changed. it wines in 1st gear and for the first time a few days ago it fell out of gear when i was pulling out of my street. i dont think its going to last much longer. if the tranny dies i might just swap in a 5 speed. is there an abundance of 5 speeds in europe or anywhere for the w124 that i could order. i'd imagine they are pretty common over there. . . . ?
Old 08-03-2007, 07:44 PM   #8 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
so you want to take one of your hands off the steering when you are going thru the twisties so you can downshift?
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 08-04-2007, 04:30 AM   #9 (permalink)
ksing44's Avatar
Maybe your Bowden cable has too much slack. You can adjust the Bowden cable a little to achieve an easier kickdown. The adjustment is very accessible under the hood next to the throttle linkage. You can turn it a little and drive to try it out. Then turn a little more and try it again. You can definitely get the car to be more responsive to peddle movements, although you can also go too far the other way and get so it never shifts into 4th gear. Just give it a try and see what you think.
I just couldn't give up on my 1995 E320.
I think it might be like always going back to that same bad relationship with an ex girlfriend.
You feel you love them too much, or you are just too stupid to know any better.
ksing44 is offline   Reply With Quote
any idea? 3xnet W140 S-Class 4 11-26-2005 09:43 PM
Cool car , cool people jef_1_f R129 SL Class 3 08-26-2005 08:44 AM
Any idea what this is.... bse500sel W126 S,SE,SEC,SEL,SD,SDL Class 8 04-05-2005 08:40 PM
off topic, but cool very very cool belosch G-Class 2 07-17-2004 08:15 AM
Good Idea, or Bad Idea dasboost W202 C-Class 0 03-10-2004 07:07 PM
