Old 07-21-2007, 10:43 AM   #1 (permalink)
and007ca's Avatar
Vehicle: 1986 560SEC TT KS,1988 300CE,1990 560SEC 2nd GEN.KS.1990 560SEL AMG,1985 W126 [parts]
Will it fit?
I love this rims.Will it fit on the 88 300CE? Thanks .. eBay Motors: Original Factory New in box Mercedes AMG Rims 17" (item 120142435894 end time Jul-22-07 11:46:59 PDT) or eBay Motors: Original Factory New in box Mercedes AMG Rims 17" (item 120142435894 end time Jul-22-07 11:46:59 PDT)
and007ca is offline   Reply With Quote
Old 07-21-2007, 01:13 PM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 94 E420
Its a staggered set, the fronts are fine but the rears will rub if you don't roll the fender.
Eliot is offline   Reply With Quote
Old 07-21-2007, 01:40 PM   #3 (permalink)
and007ca's Avatar
How can I do that
Old 07-21-2007, 01:59 PM   #4 (permalink)
Vehicle: 94 E420
Heres an example with a BMW E39. It would be the same process with your Merc.
Old 07-21-2007, 07:46 PM   #5 (permalink)
and007ca's Avatar
WOW ,thanks...I will look for the tool first.
Old 07-21-2007, 07:54 PM   #6 (permalink)
zudeck's Avatar
Vehicle: 1988 300 E
They will fit no problem, IF your car isn't lowered.
You could still lower it, but you will need to put 225's on the rear and adjust camber. But fender rolling, is definitely the proper way to go.
I have the exact same setup, with 225's on the front and 245's on the back, and my car isn't lowered YET.
zudeck is offline   Reply With Quote
Old 07-21-2007, 08:50 PM   #7 (permalink)
and007ca's Avatar
To bad but it is lowered.Love to see yours if i can..Im in Misssissauga at 10 and Kennedy.Let me know if you have time ..PM me..
Old 07-21-2007, 09:20 PM   #8 (permalink)
Vehicle: 94 E420
The following are for the installation of AMG three piece wheels 17x8.5 ET 30 on the W124 Chassis.
Old 07-22-2007, 03:07 AM   #9 (permalink)
Inline6's Avatar
Date registered: Aug 2006
Vehicle: '87 260E, '97 Nissan VQ Cefiro
My friend had this exact set. We tried installing it in his 124, the fronts we fine, the rears were not, not only did it rub, the fender would sit on the edge of the tires. The car is lowered by 2 inches. This set is best for 123's and 126's. Unless you're willing to flare your fender or roll them and push your camber to at least negative 3.
Inline6 is offline   Reply With Quote
Old 07-22-2007, 03:55 AM   #10 (permalink)
and007ca's Avatar
Thanks Guys,,Thats a lot to do to fit those tiers and I dont know a guy for it and Im not going to try DYI.......Thanks again
Lowenhart LD5 - 19's .. they fit an 05' SLK will they fit my 00' CLK 430 ? MeanBenz W208 CLK Class 6 01-11-2006 06:54 AM
will 285/30/19 tire fit a 19x8.5 wheel? Will it fit? Fender clearance problems?? spine911 W210 E-Class 1 11-03-2004 05:46 PM
will 40mm offset fit a 2000 CLK 320. Do I need to drill to make them fit? kknouri The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-26-2003 08:43 AM
will s or cl 19 inch wheels fit on a 2001 c240 and if not can i make them fit and still look good? loweredbenz The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 02-04-2003 06:15 AM
WILL RIMS THAT FIT W140 FIT A W126 BODY STYLE Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-09-2002 06:25 PM
