Old 07-18-2007, 08:33 PM   #1 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
Oil Presure Loss...
Hello Forum,
I have been running into a problem with my car. Once it warms up (the temp needle is above 80) the car starts to stutter in lower rpms and the oil presure drops to between 1 and 2 at idle. As soon as I get the rpm over 1000, the stuttering goes away and the oil presure goes back to normal but it seems strange, any suggestions?
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 07-19-2007, 05:58 AM   #2 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
At idle, with a warm motor, mine drops to 1.5 - 2 bar. A tip on the gas and it is pegged at 3 bar.
Seems normal to me.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
Old 07-20-2007, 07:05 AM   #3 (permalink)
nickCR's Avatar
Sounds just like mine, hopefully it's normal. If it is then I need to get to the bottom for power loss when it's hot. That should be fun.
Oil Loss- Valve stem seals jbaril02 R/C107 SL/SLC Class 39 09-23-2008 01:21 PM
oil presure gouda2000 W140 S-Class 2 10-22-2006 09:21 AM
Oil Pressure loss with AC on and stopped. 1993MB190E W201 190E, D-Class 1 07-02-2006 09:16 PM
sudden oil loss and burning gray W124 E,CE,D,TD Class 1 02-04-2005 02:03 PM
Engine Oil Loss Continues? gasparetto W126 S,SE,SEC,SEL,SD,SDL Class 11 12-18-2004 10:14 AM
