Old 09-06-2007, 06:04 AM   #11 (permalink)
tbenner's Avatar
Date registered: Oct 2006
Vehicle: 2003 Montero Sport, 1965 Triumph Spitfire MKII (sold), 1997 Volvo 850 Wagon, 1995 E320 143k
I like my 104 engine again
I didn't like it much on Sunday or Monday either! The blocking plate I made is holding water pressure. I buttoned up the last couple of things (fan, hoses) and filled & burped it. It shook down OK last night so I drove it to work. The real test will be sitting on I-75 at rush hour when it's 92*.
The new thermostat has it running slightly hotter than it did before but other than that... no problems. Knocking on wood.
tbenner is offline   Reply With Quote
Old 09-06-2007, 11:04 AM   #12 (permalink)
Date registered: Dec 2006
Vehicle: '93 300E, '83 240D, '78 240D, Toy pickup, BMW R1100S, Yamaha TW200
tbenner, what did you use to seal the flange> I've got the oring for the rear coolant line if you need one...
Dingo Joe is offline   Reply With Quote
Old 09-06-2007, 12:46 PM   #13 (permalink)
tbenner's Avatar
The o-ring
I used the o-ring that would be used to seal the pipe to the oil cooler. The pump came with a complete o-ring set... just no blocking plate.
Did you ever get your oil cooler pipe off?
Old 09-06-2007, 01:07 PM   #14 (permalink)
yup, had to take off the resonance (intake) manifold and fuel rail to get to it. kind of a pain, but not technical...
water pump bypass line p100 W123 E,CE,D,CD,TD,TE Class 2 03-20-2007 02:57 PM
92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
Leaking Coolant- Water Pump Install Help? jelly450 W123 E,CE,D,CD,TD,TE Class 3 07-14-2006 10:03 AM
Leaking Coolant - Water pump? vanaaken W202 C-Class 0 02-07-2005 02:58 PM
Auxiliary Water pump Leaking Coolant pesuazo W124 E,CE,D,TD Class 10 02-08-2003 07:00 AM
