Old 07-13-2007, 09:00 AM   #1 (permalink)
Date registered: Nov 2005
Primer Pump on OM603 300td w124
Hi there,
i let my 87 300td with 140,000 miles sit for a month while i was away and now it wont start. i had the same problem on my last one where air would enter the system. I remember buying a special socket to purge/prime the diesel back to the injectors, but that was years ago and i dont have it anymore.
any ideas where I can buy one of these special tools and where it goes?
is there a way to avoid this in the future?
thanks for all your help, i really need to get back on the road!
hellspcangel911 is offline   Reply With Quote
Old 07-16-2007, 04:51 PM   #2 (permalink)
i got it working by flooring the accelerator, and cranking it in 20 second intervals. but since i travel alot and the car often sits for weeks at a time i need to figure something else out, this is a horrible way to waste a starter. Any ideas?
thanks
Primer pump assy...lift pump? Stevenpfaff W123 E,CE,D,CD,TD,TE Class 9 05-16-2007 05:22 AM
primer pump replacement p100 W123 E,CE,D,CD,TD,TE Class 2 04-24-2007 09:13 PM
300TD Wagon Primer Pump Question madeintaiwan W124 E,CE,D,TD Class 0 09-30-2006 09:37 AM
primer pump leak MichaelWater W123 E,CE,D,CD,TD,TE Class 4 03-22-2006 04:42 PM
Changing primer pump gsmith3390 W123 E,CE,D,CD,TD,TE Class 1 08-17-2004 04:10 PM
