Adjusting EHA? 1990 300e 2.6 doesn't appear to have adjustment feature... - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-10-2007, 09:02 AM Thread Starter
russ g's Avatar
Date registered: Apr 2006
Vehicle: 1990 300e 2.6
Reading about adjustment of eha but on my car I don't really see any type of adjustment feature. Again, this is the black box mounted on to the back side of the Fuel distributer correct? I can find a plug in but no adjustment screw anywhere.
Thanks
Russ
russ g is offline
post #2 of 4 (permalink) Old 07-10-2007, 09:19 AM
Date registered: Nov 2003
Vehicle: 92-93 MB E320
if you removed the EHA you will be able to see a gold screw. this gold screw is only a cover for the adjustment. remove this screw.
adjust only by 1/8 clockwise
with regards to your idle problem, clean and wipe the throttle plate and housing with a carb cleaner
and also change your fuel filter and will change fuel accumulator as well
have the same problem as yours
rvenerac is offline
post #3 of 4 (permalink) Old 07-10-2007, 09:35 AM Thread Starter
russ g's Avatar
Did the adjustment of EHA have an effect for you? I have just in last couple days, cleaned out plate and whatever i could reach inside the throttle body plus shot carb cleaner through throttle body while running, replaced fuel filter. Where do I find the accumulator?
russ g is offline
post #4 of 4 (permalink) Old 07-11-2007, 10:45 AM
accumulator beside fuel filter (faulty accumulator can cause low idle)
EHA adjustment will give you more aggressive/responsive acceleration and will correct sluggishness but dont go beyond 1/8 turn coz it will have hard starting.
another way to gain a similar result without adjusting the EHA is by putting a 50k ohms variable resistor or potentiometer in series to the green-violet wire of the engine coolant sensor fooling the computer to think that your engine is colder and it will make it run a little richer (ECU control on EHA via engine temp sensor)
i have this set-up and is very happy with it.
rvenerac is offline
    1990 300e vs 1989 300e jfine W124 E,CE,D,TD Class 17 08-17-2015 07:02 AM
    EHA replacement on 1990 300E 4matic help manjmo W124 E,CE,D,TD Class 0 11-08-2006 10:42 AM
    EHA puzzle 1991 300E 4matic franan W124 E,CE,D,TD Class 1 11-03-2006 08:33 AM
    Adjusting EHA on 1986 300E dff3 W124 E,CE,D,TD Class 4 10-14-2005 05:55 PM
    What does adjusting the EHA do? GRAND MASTER B W126 S,SE,SEC,SEL,SD,SDL Class 1 09-29-2005 12:35 AM
