» Site Navigation
» Other Sites
Old 07-03-2007, 12:01 AM   #1 (permalink)
Date registered: Feb 2006
Vehicle: E220 1994
Eibach springs PRO KIT Part #2517.140
Anyone used this Eibach PRO KIT on their benz? Impressions, suggestions?
Thanks.
razzor82 is offline   Reply With Quote
Old 07-03-2007, 12:56 AM   #2 (permalink)
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
Thanks.
I have an Eibach kit on my 230CE, but not exactly sure wich one is it, since the last owner installed it.
If I had to bet, I'd say it lowered about 20 mm. The 17" Monoblocks fit just perfect, sitting along the fender's line.
The confort was, obviously, sacrified but not much though.... in my opinion, I'd rather have all my W124s with this springs than the stock ones because these greatly improve the handling and emergency steering response.
The 17s also have a lot to say when driving fast, but the Eibachs are definatly a good start.
Do you have a link with specs to that p/n?
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline   Reply With Quote
Old 07-03-2007, 12:58 AM   #3 (permalink)
MiguelXJ's Avatar
nm, found it:
eBay Motors: EIBACH Pro-Kit Springs 85-95 Mercedes 300E 300CE E320 (item 190120528340 end time Jul-06-07 14:50:40 PDT)
Old 07-03-2007, 02:31 AM   #4 (permalink)
Date registered: Nov 2006
Vehicle: 92 300e w/130k, black on black
i have them and i like them a lot. only thing is to make sure that you put a realy thick spring pad in the rear end because it tends to leave the rear end about a 1/2 inch lower then the front.
92 300E with 145k, charcoal on black interior
eibach pro kit with bilstein HDs
17" amg knock-offs powder coated flat black
35% tint
westonian is offline   Reply With Quote
Old 07-03-2007, 06:52 AM   #5 (permalink)
Yal
Date registered: Sep 2004
^ Good advice. USA W124's are levelled while European W124's are slightly higher in the rear, you really can't tell until you see two specimens next to each other. In fact if you measure the gaps, front and back, before you mount the springs you'll see what I mean. The fender gap on a USA W124 tends to be less in the rear than in the front when sitting on stock springs and spring pads.
The Eibach drop is designed for the European settings so keep that in mind and go with the next spring pad up size in the rear. I have Eibachs on my car and I agree its one heck of an improvement over stock. They are not as harsh as H&Rs but provide about 80% of the control in hard turns that H&Rs have which is plenty . I had H&Rs on before thats how I know.
Yal is offline   Reply With Quote
Eibach pro-kit review #2531.140 Kevin Van Caster W140 S-Class 2 07-25-2006 05:32 PM
H&R VS EIBACH Pro-Kit Springs PixsouL W208 CLK Class 21 07-22-2006 11:28 AM
FS: Brand New EIbach pro kit lowing Springs W203 PART# 2563.140 WaveyKat For Sale, Trade & Wanted Items 0 08-25-2005 12:14 PM
Eibach Pro kit or H&R Lowering Springs? TyBenzo W210 E-Class 2 04-14-2005 06:24 AM
Eibach Pro-Kit vs. H&R Springs Dark DJ W126 S,SE,SEC,SEL,SD,SDL Class 10 05-28-2004 01:30 PM
