Old 06-26-2007, 07:47 AM   #1 (permalink)
Date registered: Aug 2006
Windshield Wiper Failed - E320 Wagon
My windshield wiper stopped working as I was changing between wiper speeds. I have checked the fuse and it is fine. I recently had the motor replaced as it was failing and caused the fuse to blow. Is there some type of relay that could be the problem, or does the problem potentially exist in the control arm on the steering wheel.
Second question is that since I purchased this car a few months ago the front wiper fluid pump does not function. Again, checked the fuses and they all look good. Any potential solutions?
mzbito is offline   Reply With Quote
Old 06-26-2007, 08:45 AM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
Remove the outer black cover on the wiper blade hub. Check if its lubricated and the guides are tight . Some units burn up as they are jammed or binding , the motor windings short out . It maybe a switch issue , check power at the unit in different switch positions .
Uboater is offline   Reply With Quote
Old 06-26-2007, 10:19 AM   #3 (permalink)
alexnatt's Avatar
Date registered: Feb 2004
Vehicle: 1988 300TE 1989 300SE
Perhaps this tutorial will help.
1988 Mercedes 300TE Wiper System
1988 300TE, 251,000 miles
1989 300SE, 89,000 miles
2000 E320 4matic wagon, 115k miles
alexnatt is offline   Reply With Quote
Windshield Wiper silverstreak W208 CLK Class 1 02-27-2007 05:18 PM
Windshield Wiper! nokkieny W202 C-Class 4 08-22-2006 07:15 AM
E320 windshield wiper cardoctor W210 E-Class 11 11-25-2005 07:22 PM
e320 wagon rear wiper not making contact at top darrenlew W210 E-Class 2 04-27-2005 01:42 PM
Failed windshield wiper --Help-- redwood W124 E,CE,D,TD Class 0 12-28-2004 03:40 PM
