Old 06-23-2007, 11:33 PM   #1 (permalink)
chinny4290's Avatar
Date registered: Aug 2005
Vehicle: 1994 E320 Coupe W124 - 1975 280S W116
Engine braking...Good or bad?
Hello guys.
ANother question.
I engine brake a lot in my car by using the shift gate by shifting down to 3 and 2, obviously in concordance with the proper revs.
Is this fine, or am I decreasing the life of my transmission and engine by doing this?
My 1994 C124 E320 Coupe
chinny4290 is offline   Reply With Quote
Old 06-24-2007, 01:21 AM   #2 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
Is this constantly being done on an automatic??
battlecat714 is offline   Reply With Quote
Old 06-24-2007, 03:59 AM   #3 (permalink)
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL, 94-E320 CAB
Originally Posted by chinny4290
Hello guys.
ANother question.
As long as you are doing it at a safe "speed match" between gears, then you should have no problem.
I've done it and still do it with every car I own with no detriment to the transmission or converter and to the benefit of brake life.
Most manuals encourage downshifting when descending grades while towing.
If the manufacturer doesn't see stress in this application, then you have no concern about trans overheating in daily driving.
My newest car a C6 Corvette with the A6 paddle shift encourages downshifts and it even "blips" the throttle to match revs.....
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 06-24-2007, 09:07 AM   #4 (permalink)
chinny4290's Avatar
Yessum....the 722.369 4 speed.
I do it a lot....when rolling down hills...when slowing up to a stop...when I'm slowing down and coming up to an on or off ramp...or when i come up behind someone slow on the highway and I'm going faster than them, I shift down to match their speed and try not to use my brakes...
Old 06-24-2007, 09:08 AM   #5 (permalink)
Vehicle: 95 E320 Cabriolet
This has been discussed on a number of forums. Concensus typically says that abject engine braking is false economy. This puts wear and tear on the engine and transmission rather than the brakes. Worn out brakes are a lot cheaper to service than worn clutches.
The only exception is when descending downhill, where you have the danger of overheating the brakes.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 06-24-2007, 11:05 AM   #6 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
Originally Posted by Kestas
This has been discussed on a number of forums. Concensus typically says that abject engine braking is false economy. This puts additional wear and tear on the engine and transmission rather than the brakes vs not using engine braking. Worn out brakes are a lot cheaper to service than worn clutches.
The only exception is when descending a long, severe downhill, especially if towing a trailer where you have the danger of overheating the brakes.
emphasis mine
'O=00=O' BMW 2002. long live the legend.
neanderthal is online now   Reply With Quote
Old 06-24-2007, 11:50 AM   #7 (permalink)
Date registered: Jul 2004
False economy, maybe but who said it was being done for economy?
deanyel is offline   Reply With Quote
Old 06-24-2007, 01:40 PM   #8 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
From a purely mechanical sense , the worst engine condition is high rpm uncoupled . So on a stick when you depress the clutch at 3000- 6000 would the worst. Since most auto trans are full lock up at rpm ,only crazy down shift would cause problems ( like 55 mph shift to second ) ( 100 mph shift to 3rd ).
As with all machinery the speed and smooth application of the load is key . Done correctly downshifts / engine braking combined with controlled braking spreads the load over two systems . Holding the brakes in a long slope would be a problem in high gear in some cases .
Uboater is offline   Reply With Quote
Old 06-24-2007, 05:30 PM   #9 (permalink)
If not done for economy, why is engine braking even considered?
This is not a balanced way to brake a car. Brake systems are engineered to safely distribute the braking load between front and rear. Adding engine braking to the mix can cause the rear wheels to skid prematurely.
I think engine braking is done by drivers with itchy fingers. I see no value with engine braking except for the abovementioned long slopes.
Old 06-24-2007, 05:43 PM   #10 (permalink)
chinny4290's Avatar
Sorry, I'm a bit confused by your first part.
When I engine brake...I don't let the revs go above 4500-5000 RPM. I've driven my car plenty to know when to downshift in the shift gate.
bad emissions + rough idle @ 750 = no suck or bad engine? veryslowbenz W126 S,SE,SEC,SEL,SD,SDL Class 30 09-15-2007 04:05 AM
Engine surge when braking ahmorris W210 E-Class 1 04-16-2007 11:35 PM
Restore engine restore? Good or bad for MBs 240DieselPower W123 E,CE,D,CD,TD,TE Class 27 04-02-2007 04:40 AM
Vibrations between 50-80 km/h on engine braking festerpig W124 E,CE,D,TD Class 1 02-28-2007 06:23 AM
98 s500 engine braking? rambo006 W140 S-Class 0 11-22-2004 11:51 AM
