» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 06-14-2007, 02:42 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 1990 300TE
A/C Dash vent problems
Hello all- New owner here of a great '90 300TD and I absolutely love the car and am constantly amazed at the quality. One small glitch I just noticed (now that the temps are up and the A/C is on) is the central air diffuser doesn't work. Manual control is open, side vents, lower vents, and windscreen vents all pump cold, but that center one would certainly increase efficiency. Any ideas that don't include tearing apart the dash, which would have to be a PIA project?
Many thanks in advance.
BoRegards is offline   Reply With Quote
Old 06-14-2007, 02:52 PM   #2 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 222111 miles "Gunter", 1999 ML320 187000 miles "Fizgig"
Center dash vent
Find the vacuum manifold (underneath dash passenger side behind glovebox) put vacuum to each line and see if a stronger vacuum will open center vent. If so its a CCU (climate control unit issue) If not the rubber diaphram in the pod is toast and must be replaced, meaning dash has got to come out.
macdrone is offline   Reply With Quote
Old 06-14-2007, 03:44 PM   #3 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 98 S500
Bo,
When you have the system in econ mode and the temp wheel at min. , are you getting air from the center vents?
Welcome to the forum........
Jayare
Jayare is offline   Reply With Quote
Old 06-14-2007, 03:52 PM   #4 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300TE x 2, 88 300E x2 (parts), 90 300TE 4Matic (parts)
Air does not always come from the center vents when the a/c is on. The difference between set temp and interior temp must reach a certain value before the system goes to max cool mode.
If you turn the set temp way, way down the center vent should blow cold air.
augapfel is offline   Reply With Quote
Old 06-16-2007, 06:47 AM   #5 (permalink)
Vehicle: 1990 300TE
Jayare;
Thank you for the welcome. There is an amazing amount of good info and knowledge here. Unfortunately, nothing from the center vents at any setting or mode. This doesn't bode well, does it?
Old 06-16-2007, 06:52 AM   #6 (permalink)
Vehicle: 1990 300TE
Hello Augapfel- I think we had the temp differential yesterday. (90+ F !) I'm not exactly in panic mode yet, as the cabin will cool down, eventually. Just seems that the system has to work pretty hard to do so.
Old 06-16-2007, 08:49 AM   #7 (permalink)
augapfel's Avatar
Your car would have had an R-12 system originally. Is it still R-12 or has it been converted to R-134a? A converted car will not cool as well as one still running on R-12. Still, that will not affect WHERE the air comes out.
It sounds like you may need to replace one of the vacuum actuators. I haven't done the center outlet one yet. So far only the defroster one quit on my 260 and that one is easily accesible once you pull the glove box insert. I know that some of the actuators are a REAL bear to get at. Hopefully the one on yours is not.
Old 08-14-2007, 10:49 AM   #8 (permalink)
Vehicle: 1990 300TE
Must be that clean living paying off with dividends! Pretty much resolved myself to the task of tearing out the dash to replace the actuators. While driving down the highway in 95+ heat, the car suddenly started cooling down quite nicely-the center vents started working!!!!! And have been going ever since. (couple weeks now) Gotta love that car!
Center Vent Problems hbomb2579 W126 S,SE,SEC,SEL,SD,SDL Class 3 08-24-2005 01:59 AM
Vent flap motor problems broncoisl G-Class 8 08-15-2005 12:48 PM
95 C220 A/C vent on dash does not open, why? kene W202 C-Class 2 06-29-2004 10:37 AM
E320 - dash vent control lamps Guest (MBNZ) W124 E,CE,D,TD Class 1 06-02-2002 06:15 PM
Is the center dash board vent control illuminated? Guest (MBNZ) W203 C32 AMG, C55 AMG 2 04-12-2002 12:59 PM
