Low speed wobble & high speed vibration - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-08-2007, 09:48 PM Thread Starter
AMG63's Avatar
Date registered: Feb 2007
Hey all,
I read elsewhere about people having wobble when they are driving low speed. This is apparently related to the steering damper and drag link.
Now, would this also relate to high speed wobble too? At about 120km/h the wheel vibrates badly and so does the steering wheel.
Finally is this an expensive thing to fix?
1991 300TE - Anthracite Grey, Grey MB Tex - 302,000kms (New daily driver)
1989 300TE - Smoke Silver, Burgandy MB Tex - 427,000 kms (Previously daily driver now retired)
AMG63 is offline
post #2 of 6 (permalink) Old 06-09-2007, 04:56 AM
Date registered: May 2003
Vehicle: E320 wagon
I would remove one side of the damper and pull it through the range of travel . There are dead spots of no resistance on worn units.
Low - uneven tire pressure ( right 22 left 29 ) combined with out of balance tires can add to the problem.
Uboater is offline
post #3 of 6 (permalink) Old 06-09-2007, 11:20 PM Thread Starter
AMG63's Avatar
Well one tyre was flat so I thought it was that. I checked all tyres and its still there. Its very weird, when im driving at low speeds like say 30km/h, the car feels like a wheel is going to fall off. Then at high speeds it vibrates pretty bad. Only started doign this 3 days ago.
AMG63 is offline
post #4 of 6 (permalink) Old 06-10-2007, 05:21 AM
Vehicle: E320 wagon
Depending on the type of wheel the balance weight could come off or be knocked off. Some alloy rims use "stick on weights (double sided tape) ,look around the inner part of the rim for clean spots where a weight may have recently departed from .
Every steer damper that has done bad for me , It had one peak in vibration speed . It wasn't bad all the time or in a turn. A strong steering wheel shake would indicate a damper failure
Maybe take your car in for a tire rotation at a local tire shop , once on the jacks any defect in the tires tread or weighs would be easy to find.
A damper was about $20- 50 USD easy to change , if done yourself . Link
Uboater is offline
post #5 of 6 (permalink) Old 06-10-2007, 06:26 AM
POS
POS's Avatar
Date registered: Oct 2005
Vehicle: 1966 250SE Cab, 1989 500SEL euro
Quoted: 26 Post(s)
90% of vibrations can be traced to the tires. I'd start there.
- Brian
1989 500SEL ECE
1966 Mercedes 250SE Cabriolet
1958 BMW Isetta 600
POS is offline
post #6 of 6 (permalink) Old 06-10-2007, 06:36 AM
eric242340's Avatar
Quoted: 311 Post(s)
The vibration can be attributed to a tyre, however the wobble cannot.
eric242340 is offline
if you have High Speed Vibration MADSLEG W163 M-Class 3 04-06-2006 10:03 AM
side to side shake and wobble of the car at low speed and fine tremor at high speed rbatista4 General Mercedes-Benz 5 03-25-2005 03:51 PM
High speed vibration from my high price 560. cyrusthefool W126 S,SE,SEC,SEL,SD,SDL Class 8 09-04-2004 04:24 PM
high speed shimmy / wheel wobble 420SEL Realtor The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 12-02-2003 04:07 PM
Vibration at very high speed Guest (MBNZ) W202 C36 AMG, C43 AMG 5 02-14-2002 05:17 PM
