Old 05-25-2007, 03:12 AM   #1 (permalink)
Vehicle: 300E 1987 (UK E-Plate)
1987 300E Central Locking (Drivers Door)
Hi, I have just been given a 1987 300E, There is a small problem in that the drivers door does not operate the central locking on UNLOCK. It will lock the car.. The passender door works fine. My belief this is related to a electrical connect... Any ideas please. Thanks.
Nigel300E1987 is offline   Reply With Quote
Old 05-25-2007, 05:00 AM   #2 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
It sounds like the vacuum servo/electrical switch in the driver's door is shot. A new part is cheap and relatively easy to replace. Once you get the door panel off, that is.
http://bos-engel.com/benz/servo.jpg
The white thing covers the servo and you can just barely see the connector at the bottom left.
augapfel is offline   Reply With Quote
Old 05-25-2007, 06:28 AM   #3 (permalink)
thanks.. i will try and take a look this weekend.
Central Locking & Door Assist Problem umar74 W140 S-Class 7 08-04-2008 07:07 PM
1987 300E RR door inside trim panel palford General Mercedes-Benz 1 01-17-2006 05:16 PM
Will any other models, drivers door, will also fit my 1991 300e hv82 W124 E,CE,D,TD Class 6 12-04-2005 05:49 AM
want 1987 300e door mouldings BigDise For Sale, Trade & Wanted Items 0 08-15-2005 09:08 AM
Central lock (unlock) not working from drivers door Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 08-26-2002 08:15 PM
