Old 03-03-2007, 10:22 AM   #11 (permalink)
Date registered: Jul 2004
Originally Posted by Kestas
124 440 56 32 is the number for the new wiring harness. But it could also be 124 440 29 33, especially if it was made late in the model year, as is my engine. This number is on a tag located about two feet from the engine wiring bulkhead connector, near the battery.
I thought it was a 96 model year switch over to the new number but if you have the 29 33 you should be OK. The part number should be somewhere around that source plug.
deanyel is offline   Reply With Quote
need advice before buying e320 wagon SprocketHead W124 E,CE,D,TD Class 10 11-05-2006 10:31 AM
NEED QUICK ADVICE............95 e320 wagon for $5000 los1950 W124 E,CE,D,TD Class 2 10-10-2006 09:07 AM
Looking for an E320 4matic Wagon. Advice? CookiePuss99 W210 E-Class 2 01-12-2004 06:51 AM
1998 e320 wagon advice janos_z W210 E-Class 4 05-02-2003 12:35 PM
Advice needed: '99 E320 4Matic wagon vs. '00 ML 430 Guest (MBNZ) W210 E-Class 7 05-23-2002 02:52 PM
