» Site Navigation
» Other Sites
Old 02-23-2007, 06:43 PM   #1 (permalink)
Date registered: Sep 2004
Send a message via AIM to DamianDiesel
tranny issue???
87 300d here. Problem is getting worse so i want to be sure its the tranny cuz i may have an extra to swap it with. Ill explain it as best as possible. On the highway if i try to accelerate, and im not talking about flooring it, the car will not move and engine will rev past 5k RPM when i hear that i back off so i dont over rev but it will usually go back to normal after i let go of the pedal all together. It is happening alot more frequently now so im worried about damaging the engine. Second problem is that when i do floor it from slow speeds it almost feels like the tranny has trouble shifting (it feels like it shifted twice instead of once like it should). Third and final problem is that from a stand still the car will stutter during the gear change from 1-2 (i think) when it is floored, the rear wheels will jolt a few times before going into gear. The only thing that is not stock is the differential which was swapped out for one from an 89' diesel. And will a 300e tranny fit my car if needed?. Thanx in advance
DamianDiesel is offline   Reply With Quote
Old 02-23-2007, 07:24 PM   #2 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
Tranny
First I would suggest fluid change (that means empty out the torque converter also, hex nut) Make sure its at the right level and somewhere there is a shift adjustment T to fix some of the issues. If you changed out the rear dif I would check that first, low fluid, leaking could be slipping due to sludge if you didnt use synthetic oil. Hope that helps. Could also be the B1 or B2 piston going out ( about 75 dollars a piece ).
macdrone is offline   Reply With Quote
Ugh. I think I have a tranny issue. :( J-bird W163 M-Class 29 09-30-2006 04:23 AM
Auto. Tranny Issue battlecat714 W124 E,CE,D,TD Class 5 07-02-2006 05:13 PM
Resolution for my tranny and S/C issue bbsilver R170 SLK Class 3 05-30-2006 12:25 PM
Help Please!! Tranny vacuum issue. joepilot W126 S,SE,SEC,SEL,SD,SDL Class 2 02-20-2006 12:19 PM
Tranny issue, help please dtkw W126 S,SE,SEC,SEL,SD,SDL Class 5 02-08-2005 07:25 PM
