1988 300CE M103 Twin Turbo Project - Page 3 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 04-21-2007, 05:52 AM   #21 (permalink)
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Originally Posted by roccopup
Would you be kind enough to tell me which UK dealer has these in stock for my E320? Are they asking £1000?!
Many thanks
Hughes of Beaconsfield ( telephone: 01494 672141 ), ask for John Pearson in the parts department.
Not sure what kits are still available, but the 1000 ponds sterling (+ VAT if you are in the U.K.) is correct.
It also includes a complete large bore (twin 2" pipes) stainless steel exhaust system.
TURBOTECHNICS TWIN TURBO M103 WIDEBODY
1971 280SL ROADSTER
1988 300CE TT WIDEBODY COUPE
1994 E320 CABRIOLET
1999 C43 AMG SEDAN
2005 G55K AMG TRUCK
2008 CLK63 AMG BLACK SERIES COUPE
RBYCC is offline   Reply With Quote
Old 04-21-2007, 06:14 AM   #22 (permalink)
appatula's Avatar
Date registered: Aug 2006
Vehicle: 1980* 280CE, 1999* C280, CURRENT 1986* 300E
Send a message via AIM to appatula
Pictures!!?!
|_1st-1980 280CE=TOTALED_|_2nd 1999 C280=TOTALED(rollover)_|_Current 1986 300E 160K_|_1995 AMG C36 145k_|
Visit RHW's, aka Rich's Website For More Pics!
appatula is offline   Reply With Quote
Old 04-22-2007, 04:54 AM   #23 (permalink)
RBYCC's Avatar
Originally Posted by appatula
Pictures!!?!
None yet...
Install being done by Willow Automotive in Chicago.
Hope to be complete by the end of the week.
Then the long wait for FedEx to pick the car up and bring it home !!!
Will post pix as soon as it's back !!!
Old 07-12-2007, 12:23 PM   #24 (permalink)
Date registered: Feb 2003
Vehicle: 360TE AMG; 500E
Originally Posted by redwood
I would leave the trans alone until it plays up. you would be surprised how strong mercedes driveline components are! If and when you needed to replace the trans, a unit from a 400e would definitely suffice. the trans for 400 and 500e is sourced from the S-class and is also essentially the same box behind the mighty 600SEL! A car with something like 390lb.ft of torque.
The tranny for the M119 engine (400E & 500E) will NOT bolt-up to a M104/M104 block.
:-) neil
:-) neil
1988 360TE AMG
1993 500E
1995 E320 wagon
M104-AMG is offline   Reply With Quote
Old 07-12-2007, 12:48 PM   #25 (permalink)
RBYCC's Avatar
Install complete, much quicker then I expected.
Drove about 250 miles so far and today installed a G-TECH SS to get some performance figures.
As soon as I find some open road, I'll do a few launches and post the results !!!
Suspension well balanced using H&R sport lowering springs (1.5" drop), Bilstein HD's and Sportline front and rear sways.
Zimmerman drilled rotors and Textar pads.
Replacing the supplied coil hoses with modern silicone and ss tube.
Waiting for a silicon elbow to complete the turbo intake side.
Supplied piggyback electronics for the additional injectors was non adjustable, ran 17.5 AFR under boost and compensated by retarding ignition.
Replaced with a Split Second 3D mappable via laptop controller and AFR's are 12.5 under boost.
Old 07-12-2007, 12:52 PM   #26 (permalink)
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
Send a message via AIM to mcbear
Looks GOOOOOOD. Glad to see you are happy.
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline   Reply With Quote
Old 03-20-2008, 10:49 AM   #27 (permalink)
3litre190's Avatar
Date registered: Mar 2008
Vehicle: 1988 190E 3.0L (M103)
Any Chance you got those figures on the power, etc.?
3litre190 is offline   Reply With Quote
Old 03-21-2008, 05:26 AM   #28 (permalink)
RBYCC's Avatar
If I recall on the Mustang load dyno the pull was about 209HP and 238 torque, which is a 55% / 64% increase over stock.
There was a 30% drivetrain loss factor as indicated by stock published data and pre turbo install pull.
135/145 versus 177/188.
The Mustang load dyno reads about 17% lower then an inertia type dyno.
Adjusting to the more common dyno gives about 251 / 287 at the rear wheels.
I'm not interested in obtaining high numbers as the dyno is a tuning tool.
I look at performance which is low 5 second 0-60 times, 1/4 mile possible this week end.
In essence as fast as most NA early AMG V8's
Old 03-21-2008, 06:55 AM   #29 (permalink)
EvoGuy's Avatar
Date registered: Dec 2006
Vehicle: 2004 E500 Wagon, 2004 E55 AMG
I'm curios to see what times you're getting in the 1/4mile run! It should be low 14's or maybe high 13's! Good luck and keep us posted.
EvoGuy is offline   Reply With Quote
Old 03-21-2008, 04:56 PM   #30 (permalink)
RBYCC's Avatar
Local track cancelled the last three Sunday "test and tune" sessions because of either rain or high winds.
This Sunday they officially open and I'll try to get there and hope for at least 2-3 runs.
I'd be ecstatic with a high thirteen and about 100MPH trap speed.
More interested in the trap speed as I'm not sure how it will hook up off the line.
Sunday should be high 40's, low 50's and low humidity which is ideal turbo weather.
If I get there I'll post the time slip.
Bookmarks
Twin Turbo system acquired for m103 talbir W126 S,SE,SEC,SEL,SD,SDL Class 71 05-01-2007 09:54 AM
Info On Tune Up For 300ce 1988 W/t Mosselman Turbo LORINSER_SL W124 E,CE,D,TD Class 8 06-30-2006 07:44 PM
FS: 1988 300ce AMG Twin Turbo BZNHALFDZN For Sale/Wanted/Trade/Giveaway 16 06-05-2006 08:12 PM
Rare Collectible-300ce AMG Twin Turbo - $18000 kanoti W124 E,CE,D,TD Class 3 05-27-2006 10:13 AM
300CE Twin Turbo Project Guest (MBNZ) W124 E,CE,D,TD Class 1 08-03-2000 10:13 AM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
