Old 02-24-2007, 01:38 PM   #11 (permalink)
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Originally Posted by nkpnkp
After reading this,does it means stay with OEM. Seems like lots of you have problems with this brand?
My understanding is the SPORT shock [which is mainly used on the Sportline, 500E and any lowered 124 has had a bit of QC problem but their main products are very good. I have them on all our cars/trucks and recommend them to everyone. Mine is the only one I have personally seen that has failed, although as I previously posted, I have seen others noted. I have been using Bilisteins for over 35 years.
We run them on track cars, which get very hard treatment with no problems at all.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2006 E500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 02-28-2007, 04:18 PM   #12 (permalink)
Date registered: Jan 2006
Vehicle: '89 300 TE, '02 E430
Send a message via MSN to markwill
Found the problem with the grumbling noise. I had the catalytic converter replaced a few months ago and it seems it or part of the the exhaust was placed against the underside of the car so that it touched it, when it vibrated against the car it was amplified inside. Quick and inexpensive fix, and now much more pleasurable to drive.
markwill is offline   Reply With Quote
Old 03-03-2007, 06:33 PM   #13 (permalink)
mcbear's Avatar
Vehicle: 500Es
Got a package in for Bilstein today with a new right front shock. Note just said that the original had a failure and that I got a new one. They did not specify the failure. Put it on and the noise problem was gone.
WTB: Struts Jippi W201 190E, D-Class 1 02-11-2007 12:49 AM
Struts willieg W124 E,CE,D,TD Class 2 02-24-2006 01:48 AM
ML 55 Shocks & Struts vsNYC W163 M-Class 0 09-23-2005 08:55 AM
Help-new struts Guest (MBNZ) W201 190E, D-Class 1 05-20-2002 02:36 PM
Bilstein Hd Shocks & struts for 89 190e 2.6 Guest (MBNZ) W201 190E, D-Class 3 01-10-2001 02:27 PM
