Old 02-16-2007, 06:43 PM   #1 (permalink)
Date registered: Feb 2007
Advice on flex joint replacement
Hi, I am going to be attempting to replace the flex joint on the driveshaft of my 1995 E320 wagon this weekend. It looks fairly straight forward but I just wanted to see if I could get any hints or tips before I jump in.
Thanks very much,
Jim Lee
sasjzl is offline   Reply With Quote
Old 02-16-2007, 07:43 PM   #2 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
It's more of a pain in the butt than you might think. Are you replacing the front flex joint, the rear, or both?
The problem is that the transmission tailshaft and the differential pinion shaft each have a long protruding nipple that slides into the ends of the driveshaft. Therefore it's not a simple matter of unscrewing all those flex joint bolts and simply dropping the driveshaft end. It won't drop and you can't slide the driveshaft forward or rearward enough to disengage. You may have to disconnect the driveshaft center support and that is a pain to access with the exhasut system being right below it. I can't remember the way Idid it last time but I think you get the general picture.
http://bos-engel.com/benz/yokenut.jpg
augapfel is offline   Reply With Quote
Old 02-17-2007, 07:30 AM   #3 (permalink)
Date registered: Jul 2004
I assume you are doing the front. It's not easy but not all that tough either. True that it doesn't simply drop in but you don't have to disconnect and shorten the driveshaft - you can lower the exhaust and an exhaust shield you can pull the driveshaft end down far enough that you can slide the flexdisk in and out at a 45 degree angle. It's probably a couple hours of good work. Of course you need to have the driver's side rear wheel off the ground so you can spin the driveshaft to get at the flexdisk bolts. It's nice to have a racheting box wrench.
deanyel is offline   Reply With Quote
Old 02-24-2007, 06:16 AM   #4 (permalink)
nkpnkp's Avatar
Vehicle: 1995 E320
Send a message via MSN to nkpnkp
Smile Flex Disc
I end up paying the pro to do it. That kind of job is not for me
nkpnkp is offline   Reply With Quote
Flex Disk Replacement MBowerson W201 190E, D-Class 7 07-04-2007 11:56 AM
ball joint replacement picklesam W126 S,SE,SEC,SEL,SD,SDL Class 9 10-11-2006 08:19 AM
Ball Joint replacement kingjames63 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-06-2005 01:40 PM
Ball Joint Replacement AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 14 08-18-2005 11:20 AM
Ball joint replacement SuperFermi W140 S-Class 1 09-08-2004 05:22 PM
