Old 02-15-2007, 07:59 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 500E, E320 Wagon, 300CE, 190-16V, 190E 5spd
26 Beeps. What does it mean?
I had a CEL on. I counted 26 "beeps". What does it mean? Anybody with a book?
The car in question is a 1994 E320 wagon.
Funny thing is after I counted the lights, the CEL disappeared without my resetting it. But still, I'm curious what the 26 "beeps" mean.
Thanks a lot guys...
malmon is offline   Reply With Quote
Old 02-16-2007, 08:02 AM   #2 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
1 No faults.
2 Oxygen sensor inoperative.
3 Lambda control inoperative.
4 Air injection inoperative.
5 EGR inoperative.
6 Idle speed control inoperative.
7 Ignition system failure.
8 Coolant temp sensor-open or short circuit.
9 Intake air temp sensor-open or short circuit.
10 Voltage at Air Mass sensor too high or low.
11 TN (RPM) signal defective.
12 Oxygen sensor heater open or short circuit.
13 Cam position sensor signal from-EZL/AKR ign. control unit defective.
14 Intake manifold pressure at start too low.
15 Full throttle Info defective.
16 Idle speed info defective.
17 CAN Data exchange-Malfunction between control units.
18 Adjustable camshaft timing solenoid-open or short circuit.
19 Fuel injectors-open or short circuit or Emission control system adaptation at limit.
20 Speed signal missing.
21 Purge switchover valve-open or shorted.
22 cam position sensor signal defective.
23 Intake manifold pressure w/ engine running too low.
24 Starter ring gear segments defective.
25 Knock sensors.
26 Upshift delay switch over valve-open or shorted.
27 Coolant temp sensor deviation between sensor ciruits 1 & 2.
28 Coolant temp Sensor.
battlecat714 is offline   Reply With Quote
Old 02-16-2007, 09:00 AM   #3 (permalink)
Thanks Jorge...
Old 02-16-2007, 11:04 AM   #4 (permalink)
anytime. nice stable by the way!
Old 02-16-2007, 08:45 PM   #5 (permalink)
bahnstormer's Avatar
Date registered: Nov 2005
Vehicle: A few...
Have you had the top engine wiring harness replaced yet? if not, code 26 could mean $1500....
bahnstormer is offline   Reply With Quote
Old 02-16-2007, 11:33 PM   #6 (permalink)
Yep... no more issues on the harness :-))
Old 02-23-2007, 10:02 PM   #7 (permalink)
26: Upshift delay switch over valve-open or shorted
My CEL appeared again this afternoon and again, I got 26 blips.
What does this exactly mean (Upshift delay switch over valve-open or shorted) in layman's language? I suppose this is connected with the tranny? How do I fix the problem? Like I said, wiring harness is OK. Where else can the problem be?
Thanks again in advance guys...
beeps Mike Suldo R170 SLK Class 1 07-30-2006 01:53 PM
Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 07:10 PM
No Voice or Beeps on Navigation dcfsf W163 M-Class 2 09-06-2005 05:09 AM
Beeps, oil symbol, and "Hi" StuttgartStud R170 SLK Class 7 03-05-2005 07:31 PM
99 c280 Brake light is on and it beeps when I drive the car HELP! paul88 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 02-04-2005 01:14 PM
