how to replace return lines
925 views 3 replies 3 participants last post by  augapfel
how hard is it to put in new injector return lines?
Thanks
The lines are just a slip fit on the nipple on the injector. Just pull up and it will slide off, but in some cases the return line will be stuck or will brake off at the nipple. Use a sharp knife to cut through the rubber and pry off. Cut new line to the proper length and slip over the nipple and push home.
Good luck
Tom
