Old 02-08-2007, 01:45 AM   #1 (permalink)
Date registered: Feb 2007
W124 Rear suspension noise
hi every one i just had a problem in which you might be able to help me with, i own a 260E w124 and every time i go over a bump in the road or crack the suspension will make a clonk noise is this normal?
george h is offline   Reply With Quote
Old 02-08-2007, 05:49 AM   #2 (permalink)
Date registered: Apr 2006
Vehicle: 1993 300D 2.5 Turbo
I hear the same noises from time to time on mine. I recently had suspension work done though and had the links in the rear changed, and it had made a dramatic change in handling. So I have been skepticle of the noise being a problem. Has the temperature been super cold? I park on the street in Portland, Maine so my car is practically eternally frozen cold.
Xander is offline   Reply With Quote
Old 02-08-2007, 06:51 AM   #3 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Is this "clonk" from the front or rear area? More info will help.
Jayare
Jayare is online now   Reply With Quote
Old 02-08-2007, 02:53 PM   #4 (permalink)
Date registered: Jan 2007
Vehicle: E320
Jayare
I get a creaking noise from the rear when its less than 30 degrees the first 20 minutes or so the car is used going over speedbumps before everything starts warming up from use.
jlink38 is offline   Reply With Quote
Old 02-08-2007, 04:42 PM   #5 (permalink)
kiasu's Avatar
Date registered: Feb 2006
Vehicle: 1989 260E
Ive got the same problem, so getting 4 new shocks, the problem may be a valve in one of the shocks that are noisy which you are encountering, although i do get the creeking noise from the front which is probably just from wear and tear from the hard h&r's springs..
kiasu is offline   Reply With Quote
Cracking noise in the rear suspension..... C-Rod W163 M-Class 15 04-01-2006 06:01 PM
Noise from rear suspension Andrzejek General Mercedes-Benz 1 03-08-2006 07:40 PM
Noise from rear suspension Andrzejek W202 C-Class 0 05-11-2005 06:29 AM
Suspension Noise from rear roadsession W163 M-Class 3 12-30-2002 08:32 PM
Rear suspension noise Jack R170 SLK Class 2 06-06-2001 05:57 AM
