» Site Navigation » Other Sites
02-02-2007, 07:04 PM
#1 (permalink )
Date registered: Nov 2006
Vehicle: 87 300td wagon
fuel filter washers 300td
Hi, can anyone tell me where is the proper place for the two black rubber washers that came with my new fuel filter? Thanks!
02-02-2007, 07:43 PM
#2 (permalink )
....also, in an 87 300td will I just twist the old one off or is there more to getting at the old filter and removing it... thanks
02-02-2007, 08:14 PM
#3 (permalink )
Date registered: Mar 2006
Vehicle: 1991 Mercedes 300E
if its the same as the 300e its basicly just unscrewing the 2 ends of the filter and replacing it. just once you remove the filter go backwards and you should be fine, as for new washers that came with the filters im not sure as mine was just a filter, not new bolts or washers or anything.
good luck i hope this helps
Thread Tools Display Modes Linear Mode
