Old 01-30-2007, 09:31 PM   #1 (permalink)
Date registered: Jan 2007
NitroFill Tires?
NitroFill Tires? i am wondering about filling your tires with nitrogen i heard some shops do it... any benefits?
300E 1993 121k MILES (MINE)
S500 2004 4 Matic 37,000 MILES (mine)
BMW 750Li 2007 15,700 MILES (Dad)
Lexus GS460 (Mom) 9,000 MILES (too much power)
2007 E350 4 Matic (Side Car) 11000 MILES
07 STi with a bit of work done to her... (brothers)
driving fast is half the battle
Not bad for a 18 year *october 17th old*
omairtheman1 is offline   Reply With Quote
Old 01-31-2007, 03:14 AM   #2 (permalink)
sunman's Avatar
Vehicle: 2003 C320 Sedan, 1992 400e sedan
Send a message via AIM to sunman
won't benefit you.
2003 c320 Sedan - Completely updated to 2005 spec with all euro and usa options
2002 s500 Sedan - Completely updated to 2006 spec with all USA options and some euro options.
http://web.mac.com/motorwerks
sunman is offline   Reply With Quote
Old 01-31-2007, 05:10 AM   #3 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
omairtheman1
Nitrogen is used due to its low expansion with heat, So if you lived in arizona and it was 35 in the AM and you ran the highway at noon at 110 degrees at 110 MPH your tire pressure would be more stable than compressed air fills. It would be more help to a trucker than a small low profile Rice burner tire.
Uboater is offline   Reply With Quote
Old 01-31-2007, 06:07 AM   #4 (permalink)
POS
POS's Avatar
Date registered: Oct 2005
Vehicle: 1983 500SL AMG, 1982 300D
Proven to have no benefits - gimmick.
1983 Black 500SL AMG with 5-spd manual - 44,000 miles
1982 Blue-grey 300D - 64,000 miles
POS is offline   Reply With Quote
Old 01-31-2007, 01:32 PM   #5 (permalink)
Date registered: Nov 2006
Vehicle: 92 300e w/130k, black on black
I'd say the only advantage is that nitrogen will escape from your tires at a much slower rate then normal air. If you are like some people who neglect tending to their tire pressure then it might be worth it. But then again, i've never tried it myself, so it very well could be a gimmick. There are a few websites that have info on it. hit up google.
some people claim that it improves ride which i think is bs, and tire pressure change is negligable unless you are a trucker.
92 300E with 145k, charcoal on black interior
eibach pro kit with bilstein HDs
17" amg knock-offs powder coated flat black
35% tint
westonian is offline   Reply With Quote
Old 01-31-2007, 05:20 PM   #6 (permalink)
Date registered: Nov 2005
Vehicle: 300-SEL, 300-E
Send a message via AIM to Eric@StarSuzuki
So far, Uboater is closest to the facts.
For typical (sane) street driving, you'll never see or feel or measure any difference between pure nitrogen and common compressed air (which is mostly nitrogen anyway).
However, Nitrogen is generally pure. Hence, it never has any moisture in it.
Moisture is only a problem at extremely high temperatures, which are sometimes seen in racing tires on the track. Moisture in the air is just very small droplets of water suspended in the air. But the moisture is non-compressible, and it expands with heat, displacing the gasses in the air and raising the tire pressure. At extreme temperatures (carcass temperatures of 230F or higher are common for some road racing tires), the effect is significant. Boiling the moisture is also a major concern, but only in very light weight cars that run racing slicks with very low tire pressures. At the pressures inside a typical tire, the boiling point of the moisture is raised to the point where even racing conditions won't usually boil the moisture.
westonian's comment is way off. Air is around 78 percent nitrogen, so if nitrogen doesn't leak out, neither will normal air.
Eric@StarSuzuki.com
1990 300-E (Edwina)
1988 300-SEL (Gruselda)
1987 300-E (Eva)
1982 300-SD (Dumbledore) It'll take a wizard to get him running
1988 Mazda RX-7 GXL (Roxie) May she rest in pieces
Eric@StarSuzuki is offline   Reply With Quote
Old 02-02-2007, 03:40 PM   #7 (permalink)
scoopcoupe's Avatar
Vehicle: E320 Coupe
sounds like a recipe for an explosion to me
and eric.... LOVE the names of the cars.... lol... good stuff
scoopcoupe is offline   Reply With Quote
tires. This car goes through tires like my kids through shoes. Darren R170 SLK Class 19 08-08-2008 07:40 AM
Luke......need new tires...with right tires size Classic_wong118 The Discount Tire Direct Tire, Wheel, Brake & Suspension 5 08-18-2004 02:47 PM
Are M+S tires considered a snow tires? ike W163 M-Class 3 02-26-2003 05:18 PM
snow tires or all weather tires shaysct The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-17-2002 01:34 PM
For Sale: Immaculate 2000 16" SLK 230 wheels and tires with less than 1000 miles on the wheels/tires YellowKompressor R170 SLK Class 1 03-28-2002 05:44 PM
