Old 01-26-2007, 05:24 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: '91 W124 saloon 300E 2.6 79K miles. Midnight Blue
Question Cold start valve INFLUENCING the oil pressure gauge?!!
A weird thing happened - I've disconnected the cold start valve (in attempt to find the cure for a long cranking before the engine started from cold). It looks like starting actually did improve (I need to wait for the engine to cool down properly before I'm certain)....
The problem is the engine oil pressure gauge is acting in a strange way now..... as soon as the engine starts it goes to full 3 even at low revs (600rpm circa ) - before it used to be around 1 and would go up to 3 only at higher revs....
Any ideas????
w124uk is offline   Reply With Quote
Oil pressure gauge showing no pressure justin2 W140 S-Class 1 11-06-2006 09:38 PM
oil pressure @ cold start Dzul W123 E,CE,D,CD,TD,TE Class 3 10-22-2006 05:35 PM
Cold start valve.. 1993MB190E W201 190E, D-Class 0 08-05-2006 10:48 PM
cold start valve/warm up reg/fuel in oil?? 4benzes R/C107 SL/SLC Class 0 01-28-2004 10:20 AM
Idle valve = Cold Start Valve ? maxhofer W123 E,CE,D,CD,TD,TE Class 1 01-27-2003 01:26 AM
