Old 01-26-2007, 02:58 AM   #1 (permalink)
Date registered: Jun 2005
Vehicle: 88' 260E
rough accceleration on my 260E
Hi there! I've just replaced and conditioned all the necessary parts needed to maintain the engine of this car, coz it's been stucked for a year in a garage. I've chavne all the filters, camshafts, plugs and fuel sysstems. Recently when I stepped on the gas whilst runnning there's a rough almost vibrating feel whilst accelerating, it's not smooth. There's also vibration in the engine that you'll also feel it inside the car, although I just replaced the engine support. I'm gonna bring it to another mechanic to check out the car, but any suggestion and advices will be so much appreciated, thanks!
xdgr8 is offline   Reply With Quote
Old 01-26-2007, 05:07 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: '91 W124 saloon 300E 2.6 79K miles. Midnight Blue
I thought the 206E was a SOHC not a DOHC and I'd say a new camshaft is a bit of an expense - did you have problems with valves not closing/opening properly? Did you buy a new or reconditioned camshaft(s)?
I guess you may have problems with fuel supply actually - when you put your foot down something is clogging the fuel filter or injectors and causing fuel starvation...
w124uk is offline   Reply With Quote
Help! 89 260e, Really rough idle in or out of gear patrick_044 W124 E,CE,D,TD Class 11 08-17-2007 07:59 PM
260e fredrickson W124 E,CE,D,TD Class 6 07-13-2006 08:59 PM
260E BILLSONG W124 E,CE,D,TD Class 5 10-18-2005 11:32 PM
'89 260e wardhill W124 E,CE,D,TD Class 0 04-27-2004 08:25 PM
My New 88 260E JamesBrown17 W124 E,CE,D,TD Class 6 03-29-2004 07:57 PM
