Old 01-23-2007, 10:23 AM   #1 (permalink)
autosleek's Avatar
Date registered: Nov 2006
problem locating the 19mm nut to loosen the tensioner belt
hi guys! trying to tighten my belt and try to look for the nut to loosen up the tensioner befors tightening it...pls help....any pictures would be great!thanks guys!
autosleek is offline   Reply With Quote
Old 01-23-2007, 10:24 AM   #2 (permalink)
autosleek's Avatar
by the way my car is a 1992 300te
Old 01-23-2007, 11:34 AM   #3 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
You will need to remove your fan shroud to make it easier to get to the 19MM. It is not all that easy to see, but there. Push back a hose or two and you should see it. You will most likely find a short extension to be a big help. Also, if it isn't a 19MM, as it was on 86 300E, then it is a 10MM hex as it is on my 300CE.
Good Luck,
Jayare
Jayare is online now   Reply With Quote
Old 01-23-2007, 11:57 AM   #4 (permalink)
autosleek's Avatar
hey thanks! can I also pull out the fan shroud in two pcs. I know there are two clips on top but are there more on the side or under it? thanks!
Old 01-23-2007, 05:11 PM   #5 (permalink)
Vehicle: Benz 260E and others
I hope this helps
JackD
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline   Reply With Quote
Belt Tensioner Gambino W124 E,CE,D,TD Class 6 01-09-2007 01:35 PM
HELP !!! belt tensioner wvh187 W201 190E, D-Class 1 11-20-2006 02:08 AM
BELT TENSIONER??? smokiesman W124 E,CE,D,TD Class 5 04-03-2005 08:10 PM
A/C Problem/ Belt tensioner MB4ME W201 190E, D-Class 3 09-28-2002 06:18 PM
Help! How do u remove a 99 exhaust tip? D Allen wrench nut is stuck. Can it be loosen? DLeconte R170 SLK Class 4 03-06-2002 07:15 AM
