» Site Navigation
» Other Sites
Old 01-13-2007, 10:40 AM   #1 (permalink)
Bob J
Date registered: Feb 2005
Vehicle: 1995 E320
Accessing Right Side of Transmission
I need to get at the upshift delay switch which is located on the right side of the transmission in my 1995 E320. Is there any way to remove that switch without dropping the transmission? If anyone has done this, please let me know what was involved. I'm okay with the check engine light being on every once in a while telling me that the switch is defective (or at least the vacuum line to it), rather than spending a lot of time and/or dollars to remove and replace it. Thanks all. Bob
Bob J is offline   Reply With Quote
Old 01-13-2007, 11:04 AM   #2 (permalink)
Eric@StarSuzuki
Date registered: Nov 2005
Vehicle: 300-SEL, 300-E
Send a message via AIM to Eric@StarSuzuki
I'm not sure about that switch, but I was able to get my kickdown cable out by just dropping the rear mount and lowering the tail housing of the transmission on a jack. The engine mounts have quite a big of "give" in them, and you can get a few inches of extra clearance by lowering the back end of the transmission that way.
Eric@StarSuzuki.com
1990 300-E (Edwina)
1988 300-SEL (Gruselda)
1987 300-E (Eva)
1982 300-SD (Dumbledore) It'll take a wizard to get him running
1988 Mazda RX-7 GXL (Roxie) May she rest in pieces
Eric@StarSuzuki is offline   Reply With Quote
Accessing the CD Changer MillE55 General Mercedes-Benz 5 12-17-2006 11:05 AM
Accessing 300E speakers Benzy89 Audio & Telematics Forum 2 04-20-2005 10:05 PM
Audio 20 CD - accessing aftermarket CD changer ? prion R171 SLK Class 0 07-18-2004 04:07 AM
Accessing the FAQ Guest (MBNZ) W203 C-Class 2 06-06-2001 06:55 AM
Accessing the FAQ Guest (MBNZ) W203 C-Class 0 06-04-2001 09:38 AM
