Old 01-12-2007, 05:18 AM   #1 (permalink)
jupiterpbc's Avatar
Date registered: Nov 2004
Vehicle: 1990 560 SEL & 1995 E300D
Send a message via AIM to jupiterpbc Send a message via Yahoo to jupiterpbc
1995 E300D Throttle Linkage Sticking
Ever since cold weather set in this season my throttle linkage has been sticking. From start up, I will accelerate slightly and when I let off of the pedal it doesn't return to idle. This will occur at higher accelerations as well, however, I can usually tap briskly on the pedal and get it to return to idle. Yesyerday is was extremely cold and tapping the accelerator had no effect and because of the torque my ABS took over and I was unable to stop the car correctly.
Has anyone experienced this scenario? I am convinced it is the linkage and have sprayed PB Blaster on all swivel points in an attempt to alleviate the condition....to no avail.
Any suggestions would be greatly appreciated.
1995 E300D
1990 560SEL
jupiterpbc is offline   Reply With Quote
Old 01-13-2007, 10:42 AM   #2 (permalink)
jupiterpbc's Avatar
This is a shameful "bump" of this thread in hopes of encouraging owners of this model to respond in the event you have any suggestions!
Thanks in advance and all comments are appreciated!
Throttle Linkage Location TheJimbo R170 SLK Class 8 08-08-2006 04:49 PM
throttle linkage parts larrylawrence W123 E,CE,D,CD,TD,TE Class 5 06-02-2006 10:35 AM
throttle linkage elgatoensombrero W123 E,CE,D,CD,TD,TE Class 3 01-25-2006 10:40 PM
Throttle Pedal Sticking?? Rivendel1 W126 S,SE,SEC,SEL,SD,SDL Class 6 10-28-2004 10:46 AM
Accelerator linkage sticking - 300SD barry_s_u W126 S,SE,SEC,SEL,SD,SDL Class 3 01-14-2004 08:53 PM
