Old 12-30-2006, 05:02 PM   #1 (permalink)
Date registered: May 2003
Vehicle: 1988 300TE, 1995 Audi 90quattro Sport
Send a message via AIM to GermanCarNut
Question UPDATE: I removed fuse on OVP Relay and car runs fine! Why? Should I drive w/o OVP?
In searching the forums, I found info about the OVP fuse and relay so I began to investigate.
Found that the fuse is fine, but just for giggles I decided to remove the fuse and see how/if it ran...
To my suprise, the car started fine without dying and it seems to idle and run perfect!
I removed the OVP Relay totally, and it is still fine (except for the ABS light)
Can anyone tell me why?
How do I get it to run WITH the OVP and fuse in place???
Is there any danger in running WITHOUT the OVP and fuse in place?
Please advise, I don't want to hurt my car.
Thanks!
-Brian
GermanCarNut is offline   Reply With Quote
Old 12-30-2006, 05:45 PM   #2 (permalink)
Yal
Date registered: Sep 2004
The OVP powers all the things that the computer uses to correct mixture and idle. When you remove it out of the equation those things revert to fixed values to keep the car running.
It is possible that you have a bad OVP relay.
Yal is offline   Reply With Quote
Old 12-31-2006, 12:51 AM   #3 (permalink)
sasha11's Avatar
Vehicle: W124 300D
I think that you risk yours ABS to be burried if the car voltage go high.
sasha11 is offline   Reply With Quote
OVP relay MarkC W124 E,CE,D,TD Class 10 04-20-2007 10:45 PM
OVP Relay? Dracus W201 190E, D-Class 3 07-29-2006 02:00 PM
Where can I get an OVP Relay from? Falcon6 W124 E,CE,D,TD Class 4 08-09-2005 08:13 PM
OVP relay: does yours have one fuse or two? Steve420SEL W126 S,SE,SEC,SEL,SD,SDL Class 8 02-16-2005 10:56 AM
What is an ovp relay??? Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 6 05-22-2004 09:32 PM
