The 300E has recently developed two problems. First it has been moody about starting. It will start, but it needs to be choked longer and it will dip low in the RPM range for a few seconds. Secondly the shifter is seeming very loose. When you shift it knocks against the plastic of the case and sounds like it is cracking the case. How might these problems, unrelated obviously, be best solved? Thanks.
